Hello Everyone,
I am having an issue connecting a new device where the only way it will connect is if I specify the incorrect bands in region configuration of the device profile.
I have been using Chirpstack for a few months and have multiple different devices connected to a couple gateways all working as expected. The issue occurred when I tried to add a new device (Digital Matter Yabby3), I configured the Yabby3 to use US915 (ch. 0-7, 64) and in Chirpstack set the device profile to be the same. When the device tried to connect I would get an error in the Chirpstack logs:
ERROR up{deduplication_id=e9352c79-4c9f-4220-8ef6-445cb90de6c4}: chirpstack::uplink::data: Handle uplink error error=rx_info_set is empty
Which from this forum post, I believe to be a mismatch in the band configuration.
After much trial and error, the only way I could get the Yabby3 connected was to configure the device to US915 (ch. 0-7, 64) but in Chirpstack set the device profile’s region configuration to US915 (ch. 8-15 + 65). Using this band mismatch the device works exactly as expected.
Now that the device has been running for a few days I can see under “Recieved / frequency” that the device is indeed using US915_0, despite the device profile being set for US915_1. Which makes me think the issue is on the Chirpstack side and not the device side, as the device is broadcasting on the sub-band I set it to.
I have been trying to find the reason for this but am out of my depth, any help would be much appreciated.
Notes:
I am using Chirpstack docker on a Ubuntu machine
The only modifications I have made to the US915_0 and US915_1 .toml files is emptying enabled_uplink_channels=[] as discussed in this forum post. Those are the only two regions I have enabled in the main chirpstack.toml file.
Unlike the Yabby3, none of the other devices I am using require configuring the specific bands within 915 to broadcast on, so it’s possible there is a larger issue with my region configuration I have been oblivious to so far.
There is a mismatch where the Yabby3 configuration software says (ch. 0-7, 64) is sub-band 1, whereas in Chirpstack (ch. 0-7, 64) is sub-band 0, but I assume this is simply a mismatch in naming convention and not in the actual bands used.
Images:
Yabby3 Device Profile:
Yabby3 Provisioning Tool (these are the settings I configure onto the device itself):
Yabby3 Recieved / frequency:
Files:
chirpstack.toml
# Logging.
[logging]
# Log level.
level="info"
# PostgreSQL configuration.
[postgresql]
# PostgreSQL DSN.
# SSL mode options:
# * disable - no SSL
# * verify-full - Always SSL (verify that the certification presented by the server was signed by a trusted CA and the serv>
dsn="postgres://chirpstack:*mypassword*@$POSTGRESQL_HOST/chirpstack?sslmode=disable"
# Max open connections.
# PostgreSQL connection pool.
max_open_connections=10
# Min idle connections.
min_idle_connections=0
# Redis configuration.
[redis]
servers=[
"redis://$REDIS_HOST/",
# TLS enabled.
tls_enabled=false
# Redis Cluster.
# instance.
cluster=false
[network]
net_id="000000"
# Enabled regions.
enabled_regions=[
"us915_0",
"us915_1"
[api]
bind="0.0.0.0:8081"
# Secret.
# openssl rand -base64 32
secret="*mysecret*"
[integration]
enabled=["mqtt"]
[integration.mqtt]
server="tcp://$MQTT_BROKER_HOST:1883/"
json=true
[integration.mqtt.client]
client_cert_lifetime="12months"
ca_cert="/etc/chirpstack/certs/ca.pem"
ca_key="/etc/chirpstack/certs/ca-key.pem"
[gateway]
region_us915_0.toml
# This file contains an example US915 example (channels 0-7 + 64).
[[regions]]
# ID is an use-defined identifier for this region.
id="us915_0"
# Description is a short description for this region.
description="US915 (channels 0-7 + 64)"
# Common-name refers to the common-name of this region as defined by
# the LoRa Alliance.
common_name="US915"
# Gateway configuration.
[regions.gateway]
# Force gateways as private.
# If enabled, gateways can only be used by devices under the same tenant.
force_gws_private=false
[regions.gateway.backend]
# The enabled backend type.
enabled="mqtt"
# MQTT configuration.
# Topic prefix.
# The topic prefix can be used to define the region of the gateway.
# Note, there is no need to add a trailing '/' to the prefix. The trailing
# '/' is automatically added to the prefix if it is configured.
topic_prefix="us915_0"
server="tcp://$MQTT_BROKER_HOST:1883"
username=""
password=""
# Quality of service level
# 0: at most once
# 1: at least once
# 2: exactly once
qos=0
# Clean session
clean_session=false
# Client ID
# broker. A client id must be no longer than 23 characters. If left blank,
# a random id will be generated by ChirpStack.
client_id=""
# Keep alive interval.
# This defines the maximum time that that should pass without communication
# between the client and server.
keep_alive_interval="30s"
ca_cert=""
tls_cert=""
# TLS key file (optional)
tls_key=""
# Gateway channel configuration.
# Note: this configuration is only used in case the gateway is using the
# ChirpStack Concentratord daemon. In any other case, this configuration
# is ignored.
[[regions.gateway.channels]]
frequency=902300000
bandwidth=125000
modulation="LORA"
spreading_factors=[7, 8, 9, 10]
frequency=902500000
bandwidth=125000
modulation="LORA"
frequency=902700000
bandwidth=125000
modulation="LORA"
frequency=902900000
bandwidth=125000
modulation="LORA"
frequency=903100000
bandwidth=125000
modulation="LORA"
frequency=903300000
bandwidth=125000
modulation="LORA"
frequency=903500000
bandwidth=125000
modulation="LORA"
frequency=903700000
bandwidth=125000
modulation="LORA"
frequency=903000000
bandwidth=500000
modulation="LORA"
spreading_factors=[8]
# Region specific network configuration.
[regions.network]
# surrounded gateways.
installation_margin=10
# RX window (Class-A).
# Set this to:
# 0: RX1 / RX2
# 1: RX1 only
# 2: RX2 only
rx_window=0
# RX1 delay (1 - 15 seconds).
rx1_delay=1
# RX1 data-rate offset
rx1_dr_offset=0
# RX2 data-rate
rx2_dr=8
# RX2 frequency (Hz)
rx2_frequency=923300000
rx2_prefer_on_rx1_dr_lt=0
# Prefer RX2 on link budget.
# Downlink TX Power (dBm)
# be used.
downlink_tx_power=-1
# ADR is disabled.
adr_disabled=false
# Minimum data-rate.
min_dr=0
# Maximum data-rate.
max_dr=3
# Enabled uplink channels.
# Use this when ony a sub-set of the by default enabled channels are being
# used. For example when only using the first 8 channels of the US band.
# Note: when left blank / empty array, all channels will be enabled.
#enabled_uplink_channels=[]
# Rejoin-request configuration (LoRaWAN 1.1)
[regions.network.rejoin_request]
# Request devices to periodically send rejoin-requests.
enabled=false
# The device must send a rejoin-request type 0 at least every 2^(max_count_n + 4)
# uplink messages. Valid values are 0 to 15.
max_count_n=0
# The device must send a rejoin-request type 0 at least every 2^(max_time_n + 10)
# seconds. Valid values are 0 to 15.
# 0 = roughly 17 minutes
# 15 = about 1 year
max_time_n=0
# Class-B configuration.
[regions.network.class_b]
# Ping-slot data-rate.
ping_slot_dr=8
# Ping-slot frequency (Hz)
# set this to 0 to use the default frequency plan for the configured region
ping_slot_frequency=0
region_us915_1.toml
# This file contains an example US915 example (channels 8-15 + 65).
[[regions]]
id="us915_1"
description="US915 (channels 8-15 + 65)"
common_name="US915"
[regions.gateway]
enabled="mqtt"
# Topic prefix.
topic_prefix="us915_1"
username=""
password=""
# 0: at most once
# 1: at least once
# 2: exactly once
qos=0
# Clean session
clean_session=false
# Client ID
client_id=""
ca_cert=""
tls_cert=""
tls_key=""
# is ignored.
frequency=903900000
bandwidth=125000
modulation="LORA"
frequency=904100000
bandwidth=125000
modulation="LORA"
frequency=904300000
bandwidth=125000
modulation="LORA"
frequency=904500000
bandwidth=125000
modulation="LORA"
frequency=904700000
bandwidth=125000
modulation="LORA"
frequency=904900000
bandwidth=125000
modulation="LORA"
frequency=905100000
bandwidth=125000
modulation="LORA"
frequency=905300000
bandwidth=125000
modulation="LORA"
frequency=904600000
bandwidth=500000
modulation="LORA"
[regions.network]
# Set this to:
# 0: RX1 / RX2
# 1: RX1 only
# 2: RX2 only
rx_window=0
rx1_delay=1
rx1_dr_offset=0
# RX2 data-rate
rx2_dr=8
# be used.
# ADR is disabled.
adr_disabled=false
min_dr=0
max_dr=3
#enabled_uplink_channels=[8, 9, 10, 11, 12, 13, 14, 15, 65]
enabled=false
max_count_n=0
# 15 = about 1 year
max_time_n=0
ping_slot_dr=8
