Hi!
I am testing downlink via api with DeviceQueueService : [POST] api/devices/{device_queue_item.dev_eui
My example is body:
“reference”: true,
“confirmed”: “true”,
“fPort”: 5,
“data”: “eyJkYXRhIjo”
and device_queue_item.dev_eui HEX from device but it throws an error:
Response Body
"error": "f_port must be > 0",
"code": 3,
"message": "f_port must be > 0",
"details": []
What I am doing wrong?
Thanks!
@TheHysiK
Use below example body
POST: http://localhost:8080/api/devices/{device.eui}/queue
"deviceQueueItem": {
"reference": true,
"confirmed": true,
"data": "AAA=",
"fPort": 1
Thanks! When trying example I did not removed json so problem was using json and data…
Regards!
Has someone experience with calling this api from the requests package in python?
I am not sure on how to add all header informations including the authentication token.
Solved. I am using MQTT now
