I’m trying to send a data to the end node using “/api/devices/{device_queue_item.dev_eui}/queue”
Actually, it was working several days ago. but today it responds an error message below.
This happens when the device OTAA joined (again), but LoRa Server did not signal the new AppSKey to LoRa App Server because it didn’t receive a first uplink yet.
Thus, the LoRa App Server security-context is not in sync during a short interval which causes the above error.
we are also facing this issue. What is the root cause of this issue?
What is the solution to this type of error, assume we have deployed so many devices in fields and occurs this type of issue what should we do on-field scenario.
Over the course of the life of a device (or battery), the time between the join and the first uplink should be a very small percentage - i.e. it should not happen very often. Is your device rejoining regularly?
We configured our services that sit on top of ChirpStack to queue the message until it can be successfully queued in ChirpStack. The same approach works for devices that have been registered but never joined, which also cannot queue downlinks in ChirpStack.
Or can you enqueue the DL during get_downlink_data_delay already?
Yes, there is a time-window between receiving the (first) uplink and when ChirpStack reads the queue, in which you can enqueue the downlink.
This is going to be easier in the future ChirpStack release I’m currently refactoring and cleaning up the code-base, which will also remove the limitation that you have to wait with the enqueue until the first uplink (nothing public yet).
A little background: the device keeps sending uplink messages successfully. I’ve waited for the “next uplink” and the error is persistent. I thought it could be related to the fact I was using replicas of the ns/ap server (based on wobcom / iot / Chirpstack Helm · GitLab), but them I scaled-down to one instance of each server and the error is still persistent.
EDIT:
Chirpstack App Server: 3.17.6
Chirpstack Net Server: 3.16.1
I can’t assure that it has joined after the last change I’ve made to the NS/AP instances: I’ve made several tests along with helm chat deployments options. However, I may say that all the tests were using the same DB (Postgres and Redis), so I’d expect that sessions keys would be properly stored. In fact, I’ve disabled such a device to force end-device rejoin mechanism and, after that, the problem was solved.
Seeing similar issue with a device that primarily works with downlink data (an indicator light). It joins and then doesn’t send an uplink for a long time. So app (Python) using API sees repeated:
debug_error_string = "{"created":"@1649872152.056108020","description":"Error received from peer ipv4:192.168.1.55:8080","file":"src/core/lib/surface/call.cc","file_line":903,"grpc_message":"enqueue downlink payload error: create device-queue item error: rpc error: code = InvalidArgument desc = device security-context out of sync","grpc_status":13
