Hi all, I have set up a ChirpStack OS on a RaspberryPI, which I operate in the AU_915 0-7 + 64.
The OTAA works perfectly and all the values look good to me. I’m using a RAK 813 and the end device is a Draguino LT - 33222-L, I also have tried a RAK 5205 and it’s behaving in a similar way with error 96 which is Timeout reached waiting for a packet in the LoRa RX2 Window. The server is set up with its defaults unchanged.
Joint Accept Delay 1 5000
Joint Accept Delay 2 6000
Receive Delay 1 1000
Receive Delay 2 2000
RX2 Window Data Rate 8
Rx2 Window Frequency 92330000
This is what I see on my end device output
***** UpLinkCounter= 569 *****
TX on freq 915.200 MHz at DR 5
RX on freq 923.300 MHz at DR 8
txDone
RX on freq 923.300 MHz at DR 13
rxTimeOut
On the device I have channel 0-7 +64, 8-15 +65 enabled
On the Chirpstack server, I see about 50% of the packets arriving and I can decrypt these packets.
I don’t understand the first-second RX on freq 923.300 MHz at DR 13, I was under the impression that in OTAA the values of the RX window and frequency are passed from the Gateway to the end device.
Any help would be greatly appreciated.
