I don’t know if it’s the correct section and before asking I tried to do some research but nothing was helpful for my problem.
I’ve been going crazy for days with “DevNonce has already been used”.
Given all those indicated in terms of security, I have in a laboratory environment, a local installation of chirpstack server (4.8.1) and a gateway (raspberry) with ChirpStack Gateway OS 4.3.2 Base.
I have some devices on which i need to develop various firmware and therefore variations in the device references are necessary for the tests.
I’m going crazy on the error stated above. how can I solve it?
For info:
I use OTAA activation and LoraWan version 1.1.0
appkey - does not vary
netkey - does not vary
Join EUI - does not vary
on the same device I can change the Device EUI due to testing needs
The “Flust OTAA device nonces” function does not resolve my problem.
Where am I wrong / what can I do? I’m sure I’m missing something.
thanks for the very quick response.
I am aligned with what you wrote, therefore either something in my code is not working as I think or I am doing something wrong on the ChirpStack side.
When you say, you have to delete DevNonce in ChirpStack, does this mean using the “Flust OTAA device nonces” button? Otherwise how do you do it?
What I do is:
flash a new firmware, this operation remove also persistence data.
use “Flust OTAA device nonces”.
but the problem arises.
sometime i need to change “Device EUI”, could be this operation that invalid the proces?
For RadioLib, I recommend to put in Persistence code.
There are example code for esp32 and esp8266.
I have tried before with esp32+Radiolib+ChirpStack.
Without persistence code, after Flush the DevNonce, the node will be able to join ONCE with DevNonce=0.
After that, if you reboot the node, it can not join anymore as new DevNonce=0 is no longer accepted.
first of all, thanks for your support.
Formally i have done all you write for radiollib and persistence.
After last message, i tried to re-flash my dev board 2/3 times and … now all seem to be right.
I have change nothing, same firmware, same process, same steps.
i really don’t understand, i’m sure that i’m doing somethings wrong.
