whenever i force a time synchronisation at my device, its getting a completly wrong time.
Where is the time specified that my device get from the server?
What device and how are you forcing the synchronization?
Its a luminare controller and i am forcing the synchronization with an downlink command.
Assuming we are talking about the DevTimeReq / Ans, ChirpStack tries:
- Using the GPS time from the gateways, failing that
- Gateway time, failing that
- The server time
Hi Brocaar, can I switch off “using GPS time from GW”?
as results it delivers wrong GPS time to the devices:
You can not. If the gateway provides a GPS time, then ChirpStack will assume that that time is correct. It might be better to resolve this issue at the gateway level instead.
How to do so can you explain ?
