Hello everybody,
for my studies i am currently dealing with Lora.
I use a Dragino LG01-N as a gateway and want to connect it to the Chirpstack server.
Two days ago I connected it to the server and it was shown to me as online.
The next day i wanted to make further configurations, but although I did not change any of the settings, I received an error message that I am stuck with.
I use everything under localhost in a virtual machine (opensuse)
and have taken over the settings as they are in github without changing anything.
chirpstack-gateway-bridge_1 | time=“2020-06-07T08:40:12Z” level=info msg=“integration/mqtt: publishing event” event=stats qos=0 stats_id=65fff62e-ea1f-472b-83f0-cac30fa27938 topic=gateway/a840411da0f44188/event/stats
chirpstack-network-server_1 | time=“2020-06-07T08:40:12Z” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=a840411da0f44188 stats_id=65fff62e-ea1f-472b-83f0-cac30fa27938
chirpstack-network-server_1 | time=“2020-06-07T08:40:12Z” level=info msg=“gateway updated” ctx_id=65fff62e-ea1f-472b-83f0-cac30fa27938 gateway_id=a840411da0f44188
chirpstack-network-server_1 | time=“2020-06-07T08:40:12Z” level=warning msg=“creating insecure application-server client” server=“chirpstack-application-server:8001”
chirpstack-network-server_1 | time=“2020-06-07T08:40:17Z” level=warning msg=“ccResolverWrapper: reporting error to cc: dns: A record lookup error: lookup chirpstack-application-server on 127.0.0.11:53: dial udp 127.0.0.11:53: operation was canceled”
chirpstack-network-server_1 | time=“2020-06-07T08:40:17Z” level=error msg=“gateway: handle gateway stats error” ctx_id=65fff62e-ea1f-472b-83f0-cac30fa27938 error=“get application-server client error: get application-server client error: create application-server api client error: dial application-server api error: context deadline exceeded”
chirpstack-network-server_1 | time=“2020-06-07T08:40:42Z” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=a840411da0f44188 stats_id=8e4136d7-0d89-4bc1-9067-c785d666c3cb
I would be very happy to receive an answer.
best regards, Johannes
