Hi. I’m using a Dragino like single channel gateway, and ESP 32 V2 with LoRA in ABP mode, and I have a problem with disable frame counter Validation, It seems that didn’t work because I always need to delete the device an generate new keys for the devices receives the data. How can I use disable frame counter validation. I’m working for testing purpose and I need to restart the sending data.
I don’t know, but I do know that usually single-channel gateways will give you a lot of troubles since they only work on a single channel and data-rate.
Yes, I use another 8 channel gateway and works fine. Thank you
