So I’m working on a project, landslide detection. There will be two parts of it, one a sensor node and one gateway node. The sensor node will transmit the data collected from the sensor through wio e5 development kit. Then on the gateway node there is a wio e5 mini to collect it. Then I want to show the data collected to a website so the user can access the information on it. How do I setup ? do I use TTN or firebase ?
You can for example look into:
E.g. your stack could look like this:
[Device] -> [LoRa GW] -> [ChirpStack] -> [ThingsBoard]
Or:
[Device] -> [LoRa GW] -> [ChirpStack] -> [InfluxDB] -> [Grafana]
These are just two examples, the possibilities are endless
