Hi
I’m currently try to add Dragino LT-22222-L to Chirpstack, We configure gateway with AU915_0, and the device is also AU915, and does show JoinRequest in both UI and command line log
but only show JoinAccept in the command line log, and currently on UI it’s still show status as never seen
here’s part of log from chirpstack 4
join_request{dev_eui=""}:join_accept{downlink_id=}: chirpstack::storage::downlink_frame: Downlink-frame saved downlink_id=****
:join_request{dev_eui=""}:join_accept{downlink_id=}: chirpstack::gateway::backend::mqtt: Sending downlink frame region_id=au915_0 gateway_id=**** topic=au915_0/gateway/********/command/down json=false
Currently we are really confuse about what cause the device, if you can provide guidance, that would be really helpful
