Thx. I used the template for docker-compose.yml under
Does this mean that I have to change the entries for image: in this yml file so that they point to those individual ones I use when I manually install the chirpstack on the RPi?
The ones being referenced in the standard docker-composite.yml point to a “configuration” subdirectory. Perhaps they were compiled for another architecture?
In that discussion there is no solution for arm v8. The imiages which were generated on arribada pertain to arm v7.
Do you know how to cross-compile for arm v8? I am not familiar with that.
