I have an error with setting up chirpstack-packet-mutliplexer and docker.
I followed the directions here: GitHub - brocaar/chirpstack-packet-multiplexer: Forward Semtech packet-forwarder data to multiple servers.
I feel there is an error on the page where is given:
mkdir chirpstack-packet_multiplexer/config
touch chirpstack-packet_multiplexer/config/chirpstack-packet-multiplexer.toml
I think this was meant:
mkdir chirpstack-packet-multiplexer/config
touch chirpstack-packet-multiplexer/config/chirpstack-packet-multiplexer.toml
But when I start with docker-compose start
I get the following message:
$ docker-compose start
Starting chirpstack-packet-multiplexer ... error
ERROR: for chirpstack-packet-multiplexer Cannot start service chirpstack-packet-multiplexer: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error mounting "/home/<name>/chirpstack-packet-multiplexer/config/chirpstack-packet-multiplexer.toml" to rootfs at "/etc/chirpstack-packet-multiplexer/chirpstack-packet-multiplexer.toml": mount /home/<name>/chirpstack-packet-multiplexer/config/chirpstack-packet-multiplexer.toml:/etc/chirpstack-packet-multiplexer/chirpstack-packet-multiplexer.toml (via /proc/self/fd/6), flags: 0x5001: not a directory: unknown: Are you trying to mount a directory onto a file (or vice-versa)? Check if the specified host path exists and is the expected type
ERROR: No containers to start
I am using the default docker compose file but cannot see what is going wrong.
Doe anyone have a direction (or solution)? thanks.
