Documentation questions help?
I am new to ChirpStack…as I read thru all the documentation it has become clear that I am ‘unclear’ as to exactly what I need to install to make more RPi5 be a standalone lorawan network server. The architecture pictures lead me to believe I want to install MQTT Forwarder yet there is no Raspberry Pi installation for this. I believe I want to put the MQTT broker on my gateway which makes me wonder if I should install the Gateway Bridge instead of the Forwarder. The ChirpStack section suggests I need to install MQTT, PostgreSQL and Redis as requirements would this mean if I use the Bridge or Forwarder I would have to do the same…
Another path leads me to believe I can install the ChirpStack Gateway OS Full image…Seems simple enough except there is no image to be found…the url https://www.chirpstack.io/docs/chirpstack/index.html leads to an error
In short can some please tell a Newbie exactly what it is I would want to put on my RPi5 to make it a standalone network server?
Thank you
Here you go.
https://www.chirpstack.io/docs/chirpstack-gateway-os/install/raspberry-pi.html
