Previously the documentation of the various components were stored in each repository separately. In order to make these easier to maintain (and to make it easier to make cross-references, add a search function and check for dead links), I have migrated everything into a single repository: https://github.com/brocaar/chirpstack-docs .
Apart from a restyle (using https://www.mkdocs.org/ and https://squidfunk.github.io/mkdocs-material/ ), I have re-structured a few pages to align with the MkDocs documentation organization.
If you notice any dead link of other issue, please report these here and I will fix these. Thanks!
NS page shows old style
https://www.chirpstack.io/network-server/
Geolocation Server tab missing in restyle documentation website
Geolocation Server has gone away as an independent service:
ChirpStack Application Server v3.11.0
Features
OpenID Connect authentication
This feature makes it possible to use an OpenID Connect authentication backend together with ChirpStack Application Server, for example Auth0.com . Users are automatically matched based on email address on the first login. If there is a successful match, an external OpenID Connect user identifier is associated with the user, so that even in case of an email address update, it can still be matched (and updated in the Chir…
I suppose that doesn’t help people still running it, though.
You’re right. I should make this tab visible. The documentation is still there but the tab is hidden.
I have added the geolocation tab for the above reason. The “old style” documentation is likely caused by your browser cache.
Working after clear browser cache.
Thanks, I have fixed the link (+ redirect).
martin
July 31, 2020, 7:36am
9
I’ve just noticed main menu alignment does not look right. It looks left, but centered would be better
@brocaar
I’ve noticed in Application Server Integrations --> Event Types --> ACK (JSON) JsonV3 Marsher RxInfo and TxInfo not expose by the Application Server
