I currently don’t have access to Go 1.13 and I was trying to build using go1.12. Just wanted to check if it will work.
I believe it should
That is why I provide the Docker Compose based development environment for compiling. I recommend using it as it gives you the exact same environment as used for building releases.
Thanks Brocaar. I will try it out on 1.12. If it doesn’t work then I will use the Docker compose.
