Hello everyone,
Currently, I am trying to do some simple command from Chirpstack Network Server to an end node.
The end mode is Nucleo-WL55JC1 and the code inside is the example LoRaWAN_End_Node. The callback function in the board when receiving something:
static void OnRxData(LmHandlerAppData_t *appData, LmHandlerRxParams_t *params)
/* USER CODE BEGIN OnRxData_1 */
if ((appData != NULL) || (params != NULL))
BSP_LED_On(LED_BLUE) ;
UTIL_TIMER_Start(&RxLedTimer);
static const char *slotStrings[] = { "1", "2", "C", "C Multicast", "B Ping-Slot", "B Multicast Ping-Slot" };
APP_LOG(TS_OFF, VLEVEL_M, "\r\n###### ========== MCPS-Indication ==========\r\n");
APP_LOG(TS_OFF, VLEVEL_H, "###### D/L FRAME:%04d | SLOT:%s | PORT:%d | DR:%d | RSSI:%d | SNR:%d\r\n",
params->DownlinkCounter, slotStrings[params->RxSlot], appData->Port, params->Datarate, params->Rssi, params->Snr);
switch (appData->Port)
case LORAWAN_SWITCH_CLASS_PORT:
/*this port switches the class*/
if (appData->BufferSize == 1)
switch (appData->Buffer[0])
case 0:
LmHandlerRequestClass(CLASS_A);
break;
case 1:
LmHandlerRequestClass(CLASS_B);
break;
case 2:
LmHandlerRequestClass(CLASS_C);
break;
default:
break;
break;
case LORAWAN_USER_APP_PORT:
AppLedStateOn = appData->Buffer[0] & 0x01;
if (AppLedStateOn == RESET)
APP_LOG(TS_OFF, VLEVEL_H, "LED OFF\r\n");
BSP_LED_Off(LED_RED) ;
else
APP_LOG(TS_OFF, VLEVEL_H, "LED ON\r\n");
BSP_LED_On(LED_RED) ;
break;
default:
break;
/* USER CODE END OnRxData_1 */
As far as I understand, in order to send a downlink packet from Chirpstack Network Server to this end node, I will have to make a downlink packet, which can be done in Tenant/Application/{the application you want to use}/{the device you want to control}. I have to form a packet in Queue tab and the packet is either in Hex, Base64, or JSON. However, I am not clear about how to form such packet to send to my end node. I also searched for some more reference on the document of Chirpstack but nothing hels (maybe I missed then or didnt fully understand). I also looked at the LoRaWAN frames tab but I did not get how to write one.
My question is: Is there any document/tutorial/instruction on how to form such packets and send?
Kind regards, Huy Nguyen.
