Hi Liam_Phillipp,
Thank you very much for your very detailed advice.
Regarding question 1
I understood.
For ChirpStack, I see that “FPort” in MACPayload needs to be mentioned in the Payload data as well.
Regarding question 2、
I have uploaded Confirmed data, so if the ACK is not returned, “Code: UPLINK_F_CNT_RETRANSMISSION Level: WARNING” appeared to send again with the same FCnt.
I was able to counteract this by disabling fcount verification in the “configuration” tab of the device page.
However, “Code: DOWNLINK_GATEWAY Level: ERROR” is occurring about 10% of the time.
As you advised, I would like to change the setting in Chirpstack.toml to change the timing of the Gateway downlink.
However, I cannot find where to make the adjustment.
What part of the following file should I modify?
$ sudo cat /etc/chirpstack/chirpstack.toml
# Logging.
[logging]
# Log level.
level="info"
# PostgreSQL configuration.
[postgresql]
# PostgreSQL DSN.
# SSL mode options:
# * disable - no SSL
dsn="postgres://chirpstack:chirpstack@localhost/chirpstack?sslmode=disable"
# Max open connections.
# PostgreSQL connection pool.
max_open_connections=10
# Min idle connections.
min_idle_connections=0
# Redis configuration.
[redis]
servers=[
"redis://localhost/",
# Redis Cluster.
# instance.
cluster=false
[network]
net_id="000000"
# Enabled regions.
enabled_regions=[
"as923",
"as923_2",
"as923_3",
"as923_4",
"au915_0",
"cn470_10",
"cn779",
"eu433",
"eu868",
"in865",
"ism2400",
"kr920",
"ru864",
"us915_0",
"us915_1",
[api]
bind="0.0.0.0:8080"
# Secret.
# openssl rand -base64 32
secret="you-must-replace-this"
[integration]
enabled=["mqtt"]
[integration.mqtt]
server="tcp://localhost:1883/"
json=true
Best Regards,
Hiroshi Mori
