I am working with ThingsBoard and ChirpStack thorugh an HTTP integration, as mentioned in documentation. Uplink is working properly. However, when I try to use Downlink commands, something is wrong. From TB side, I think everything is working fine because the request is done. If I take a look to CS logs, I can see the following problema when a downlink command is sent:
It is like that URL is not found. However, it seems to be correct. Any idea of what is happening?
Thanks in advance
