Hi all. I am working with a customized LoRa Gateway based on the SX1302. I made the integration with chirpstack and can see the uplink packages join request. Unfortunately I can not confirm the download packages. The next error appears in the package forwarder log. The frequency 0 that appears is for some parameter I missed in the global_conf.json?. I am using the legal packet forwarder and just modified the server address and the gateway eui.
*** Packet Forwarder ***
Version: 1.0.3
*** SX1302 HAL library version info ***
Version: 1.0.3;
INFO: Little endian host
INFO: found configuration file global_conf.json, parsing it
INFO: global_conf.json does contain a JSON object named SX130x_conf, parsing SX1302 parameters
INFO: spidev_path /dev/spidev0.0, lorawan_public 1, clksrc 0, full_duplex 0
INFO: antenna_gain 0 dBi
INFO: Configuring precision timestamp: max_ts_metrics:255, nb_symbols:1
INFO: Configuring Tx Gain LUT for rf_chain 0 with 16 indexes for sx1250
INFO: radio 0 enabled (type SX1250), center frequency 915600000, RSSI offset -215.399994, tx enabled 1
INFO: radio 1 enabled (type SX1250), center frequency 916400000, RSSI offset -215.399994, tx enabled 0
INFO: Lora multi-SF channel 0> radio 0, IF -400000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 1> radio 0, IF -200000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 2> radio 0, IF 0 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 3> radio 0, IF 200000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 4> radio 1, IF -300000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 5> radio 1, IF -100000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 6> radio 1, IF 100000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora multi-SF channel 7> radio 1, IF 300000 Hz, 125 kHz bw, SF 5 to 12
INFO: Lora std channel> radio 0, IF 300000 Hz, 500000 Hz bw, SF 8, Explicit header
INFO: FSK channel 8 disabled
INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
INFO: gateway MAC address is configured to 0016C001FF184912
INFO: server hostname or IP address is configured to “201.62.44.66”
INFO: upstream port is configured to “1700”
INFO: downstream port is configured to “1700”
INFO: downstream keep-alive interval is configured to 12 seconds
INFO: statistics display interval is configured to 20 seconds
INFO: upstream PUSH_DATA time-out is configured to 100 ms
INFO: packets received with a valid CRC will be forwarded
INFO: packets received with a CRC error will NOT be forwarded
INFO: packets received with no CRC will NOT be forwarded
INFO: Reference latitude is configured to -20.331750 deg
INFO: Reference longitude is configured to -40.359970 deg
INFO: Reference altitude is configured to 20 meters
INFO: Beaconing period is configured to 0 seconds
INFO: Beaconing signal will be emitted at 923300000 Hz
INFO: Beaconing channel number is set to 8
INFO: Beaconing channel frequency step is set to 600000Hz
INFO: Beaconing datarate is set to SF12
INFO: Beaconing modulation bandwidth is set to 500000Hz
INFO: Beaconing TX power is set to 27dBm
INFO: global_conf.json does contain a JSON object named debug_conf, parsing debug parameters
INFO: got 2 debug reference payload
INFO: reference payload ID 0 is 0xCAFE1234
INFO: reference payload ID 1 is 0xCAFE2345
INFO: setting debug log file name to loragw_hal.log
CoreCell reset through GPIO25…
CoreCell power enable through GPIO17…
ERROR: Failed to set SX1250_1 in STANDBY_RC mode
INFO: [main] concentrator started, packet can now be received
INFO: concentrator EUI: 0x0018v001ff165235
INFO: [down] PULL_ACK received in 7 ms
INFO: [down] PULL_ACK received in 8 ms
JSON up: {“stat”:{“time”:“2021-03-03 19:02:53 GMT”,“rxnb”:1,“rxok”:1,“rxfw”:1,“ackr”:100.0,“dwnb”:0,“txnb”:0}}
INFO: [up] PUSH_ACK received in 11 ms
INFO: [down] PULL_ACK received in 23 ms
INFO: [down] PULL_RESP received - token[122:151]
JSON down: {“txpk”:{“imme”:true,“rfch”:0,“powe”:20,“ant”:0,“brd”:0,“freq”:0,“modu”:“LORA”,“datr”:“SF10BW125”,“codr”:“4/5”,“ipol”:true,“size”:16,“data”:“YEIgBEKQJQBkCmUiRNvdNA==”}}
INFO: [down] a packet will be sent in “immediate” mode
ERROR: Packet REJECTED, unsupported frequency - 0 (min:915000000,max:928000000)
INFO: [down] PULL_ACK received in 16 ms
