Hello, Node Settings:
Class A,
Interval 1 hour
data confirmed
Gateway Profile:
Class B and C disabled, So it is Class A
Join Type Is ABP
What Is Happening
The Communication between the Node and the device happening perfectly for the past few months but In the Last 10 Days, The Node has not been able to get Downlink Confirmation data.
I added a Queue to send from the gateway to Node, but after 2 days Queue is still there, pending status is no.
I compared it with other devices that were installed at the same time but still able to get the downlink data from the gateway. Here is the logs of a working downlink in another device
I see this difference the class b flag is true and f_pending is true, maybe be downlink is going in pending. and why class b is true? the profile is working on class A.
*** class_b:true**
*** f_pending:true**
The device is set To class A and working for the last few months, how suddenly has it changed to Class B?
If it is set to class B by any unauthorized activity how can I set it to class A because the message I add to the queue remains in the queue forever.
i am not able to access the device but I configured commands to change parameters in Node from getaway but the gateway is not sending a single command.
It did not. In your screenshots, the class_b=false, where in one of the downlinks, it is set to true. As I already said, the f_pending and class_b share the same bit, meaning they are both true or both false. In short, for uplink look at the class_b field, for downlink f_pending.
You can reproduce this behavior by enqueueing two items, you will see the first downlink has f_pending=true as there is an other item to send, the second f_pending=false as after this downlink the queue is empty.
Other devices are successfully receiving data from the first gateway, but this one device isn’t. When I moved it to the second gateway, the pending message cleared. Since both gateways share ChirpStack, the pending message initially sent by the first gateway was cleared once it connected to the second gateway.
