Downlink Issue on Chipstack
I am using Dragino LoRa Shield V1.4 for connect chirpstack server. I can upload the data from Dragino Lora Node to chirpstack but unable to do downlink. Can you please share the Arduino code for help this issue. I want to control my Node LEDs using downlink commands from chirpstack server. Hope you understand my issue. Please help me
\Regards
Manoj G Ramachandran
Which LoRaWAN library are you using?
Can try RadioLib.
Hi Datnus,Thank you for your reply, I am using IBM LMIC Library. Let try on RadioLib.
Regards
Hi Datnus
I am trying to use Radio Lib instead of IBM LMIC Library. But my node is not communicate after I change the Library. Any another way you know please
Regards
You can also try my simpler SlimLoRa library.
It is tested with downlinks and it’s working. Currently no protection for buffer overflow, but fixing is coming. Don’t send more than 10 bytes downlink othewise stuck node with buffer overflow.
I have to write an example for downlink. Write an example if you make it and send me a Pull Request.
