Hi! I’m currently trying to send unconfirmed downlink messages to a class A device using OTAA, but unsure whether the gateway isn’t sending them, or the device isn’t receiving them.
Gateway: RAK2245 on a Raspberry Pi 3B with Gateway OS
Device: Heltec WiFi LoRa (V2) using this library: https://github.com/mcci-catena/arduino-lmic
Gateway bridge logs:
level=info msg=“backend/concentratord: uplink event received” uplink_id=2f2feeca-e8af-437e-b9f9-f106d904a0f9
level=info msg=“integration/mqtt: publishing event” event=up qos=0 topic=devices/b827ebfffecadf86/messages/events/up uplink_id=2f2feeca-e8af-437e-b9f9-f106d904a0f9
level=info msg=“integration/mqtt: downlink frame received” downlink_id=746b39b7-60ad-45c4-a28f-bbb5ea10804b gateway_id=b827ebfffecadf86
level=info msg=“backend/concentratord: forwarding downlink command” downlink_id=746b39b7-60ad-45c4-a28f-bbb5ea10804b
level=info msg=“integration/mqtt: publishing event” downlink_id=746b39b7-60ad-45c4-a28f-bbb5ea10804b event=ack qos=0 topic=devices/b827ebfffecadf86/messages/events/ack
Concentratord logs
Frame received, uplink_id: b7fbcd00-b317-46e7-aa5f-99d96eb0841a, count_us: 2637737131, freq: 868500000, bw: 125000, mod: LoRa, dr: SF7
Enqueueing timestamped packet, downlink_id: eb8ee67c-630d-4309-8a27-11102c6b7d10, counter_us: 2638737131, current_counter_us: 2638154925
Scheduled packet for TX, downlink_id: eb8ee67c-630d-4309-8a27-11102c6b7d10, count_us: 2638737131, freq: 868500000, bw: 125000, mod: LoRa, dr: SF7
Remarks
Do these logs mean that a downlink was sent? It seems so, but the logs contain the same messages when no downlink was queued. I am receiving a TxAck message, with an empty tags field (the message is not empty). The concentratord logs also contain messages saying “GPS time reference is not valid” in case that’s related to this issue.
