I’m trying to send downlinks with Chirpstack and i can’t figure out where the issue is i have a hunch that the issue is config related. So the node is a Elsys node that uses OTAA. When i schedule a downlink the downlink gets txack from gateway as far as i know. But the device doesn’t respond to the requested change.
I have tested the same setup on TTN and have had successful downlinks there. To try to rule out any hardware issues.
The gateway that i use is a Milesight UG65 that i have tested with both “ChirpStack-Generic” and “Semtech” as packet forwarder.
Is there anyone that could point me in the right direction where the issue could be?
Network Server Configuration
[postgresql]
dsn="postgres://chirpstack_ns:chirpstack_ns@postgresql/chirpstack_ns?sslmode=disable"
[redis]
url="redis://redis:6379"
[network_server]
net_id="000000"
[network_server.band]
name="EU868"
rx_window=0
enabled_uplink_channels=[0, 1, 2, 3, 4, 5, 6, 7]
frequency=867100000
min_dr=0
max_dr=12
frequency=867300000
min_dr=0
max_dr=12
frequency=867500000
min_dr=0
max_dr=12
frequency=867700000
min_dr=0
max_dr=12
frequency=867900000
min_dr=0
max_dr=12
server="tcp://mosquitto:1883"
[join_server.default]
server="http://chirpstack-application-server:8003"
[geolocation_server]
server="chirpstack-geolocation-server:8005"
Logs from scheduled downlink
chirpstack-network-server_1 | time="2021-09-26T14:33:21Z" level=info msg="gateway/mqtt: uplink frame received" gateway_id=24e124fffef11584 uplink_id=0202820f-245b-445c-a6ae-cd39b9219bdf
chirpstack-network-server_1 | time="2021-09-26T14:33:21Z" level=info msg="uplink: frame(s) collected" ctx_id=3a986303-4a72-4158-8ffe-36799a683c1e mtype=UnconfirmedDataUp uplink_ids="[0202820f-245b-445c-a6ae-cd39b9219bdf]"
chirpstack-network-server_1 | time="2021-09-26T14:33:21Z" level=info msg="sent uplink meta-data to network-controller" ctx_id=3a986303-4a72-4158-8ffe-36799a683c1e dev_eui=a81758fffe044a33
chirpstack-network-server_1 | time="2021-09-26T14:33:21Z" level=info msg="pending mac-command deleted" cid=LinkADRReq ctx_id=3a986303-4a72-4158-8ffe-36799a683c1e dev_eui=a81758fffe044a33
chirpstack-network-server_1 | time="2021-09-26T14:33:21Z" level=info msg="link_adr request acknowledged" ctx_id=3a986303-4a72-4158-8ffe-36799a683c1e dev_eui=a81758fffe044a33 dr=0 enabled_channels="[0 1 2]" nb_trans=1 tx_power_idx=2
chirpstack-network-server_1 | time="2021-09-26T14:33:21Z" level=info msg="device gateway rx-info meta-data saved" ctx_id=3a986303-4a72-4158-8ffe-36799a683c1e dev_eui=a81758fffe044a33
chirpstack-network-server_1 | time="2021-09-26T14:33:21Z" level=info msg="device-session saved" ctx_id=3a986303-4a72-4158-8ffe-36799a683c1e dev_addr=0186c9ad dev_eui=a81758fffe044a33
chirpstack-network-server_1 | time="2021-09-26T14:33:21Z" level=info msg="finished client unary call" ctx_id=3a986303-4a72-4158-8ffe-36799a683c1e grpc.code=OK grpc.ctx_id=de5ff418-721c-4f39-9196-dad0518ce498 grpc.duration=6.835966ms grpc.method=HandleUplinkData grpc.service=as.ApplicationServerService span.kind=client system=grpc
chirpstack-application-server_1 | time="2021-09-26T14:33:21Z" level=info msg="device last-seen and dr updated" ctx_id=de5ff418-721c-4f39-9196-dad0518ce498 dev_eui=a81758fffe044a33
chirpstack-application-server_1 | time="2021-09-26T14:33:21Z" level=info msg="finished unary call with code OK" ctx_id=de5ff418-721c-4f39-9196-dad0518ce498 grpc.code=OK grpc.method=HandleUplinkData grpc.request.deadline="2021-09-26T14:33:22Z" grpc.service=as.ApplicationServerService grpc.start_time="2021-09-26T14:33:21Z" grpc.time_ms=6.304 peer.address="172.19.0.8:59136" span.kind=server system=grpc
chirpstack-application-server_1 | time="2021-09-26T14:33:21Z" level=info msg="integration/http: publishing event" ctx_id=de5ff418-721c-4f39-9196-dad0518ce498 dev_eui=a81758fffe044a33 event_type=up url="http://192.168.0.118:3100?event=up"
chirpstack-application-server_1 | time="2021-09-26T14:33:21Z" level=info msg="integration/logger: logging event" ctx_id=de5ff418-721c-4f39-9196-dad0518ce498 dev_eui=a81758fffe044a33 type=up
chirpstack-application-server_1 | time="2021-09-26T14:33:21Z" level=info msg="integration/mqtt: publishing event" ctx_id=de5ff418-721c-4f39-9196-dad0518ce498 dev_eui=a81758fffe044a33 qos=0 retain=false topic=application/1/device/a81758fffe044a33/event/up
chirpstack-network-server_1 | time="2021-09-26T14:33:21Z" level=info msg="device-queue deleted" ctx_id=3a986303-4a72-4158-8ffe-36799a683c1e id=117
chirpstack-network-server_1 | time="2021-09-26T14:33:21Z" level=info msg="pending mac-command block set" cid=LinkADRReq commands=1 ctx_id=3a986303-4a72-4158-8ffe-36799a683c1e dev_eui=a81758fffe044a33
chirpstack-network-server_1 | time="2021-09-26T14:33:21Z" level=info msg="gateway/mqtt: publishing gateway command" command=down downlink_id=3a986303-4a72-4158-8ffe-36799a683c1e gateway_id=24e124fffef11584 qos=0 topic=gateway/24e124fffef11584/command/down
chirpstack-network-server_1 | time="2021-09-26T14:33:21Z" level=info msg="storage: downlink-frame saved" ctx_id=3a986303-4a72-4158-8ffe-36799a683c1e token=15000
chirpstack-network-server_1 | time="2021-09-26T14:33:22Z" level=info msg="backend/gateway: downlink tx acknowledgement received" downlink_id=3a986303-4a72-4158-8ffe-36799a683c1e gateway_id=24e124fffef11584
chirpstack-network-server_1 | time="2021-09-26T14:33:22Z" level=info msg="sent downlink meta-data to network-controller" ctx_id=3a986303-4a72-4158-8ffe-36799a683c1e
chirpstack-application-server_1 | time="2021-09-26T14:33:22Z" level=info msg="downlink tx acknowledged by gateway" dev_eui=a81758fffe044a33
chirpstack-network-server_1 | time="2021-09-26T14:33:22Z" level=info msg="finished client unary call" ctx_id=3a986303-4a72-4158-8ffe-36799a683c1e grpc.code=OK grpc.ctx_id=83452df4-0a42-469b-b19a-bc54ba66a25d grpc.duration=2.067392ms grpc.method=HandleTxAck grpc.service=as.ApplicationServerService span.kind=client system=grpc
chirpstack-network-server_1 | time="2021-09-26T14:33:22Z" level=info msg="sent tx ack to application-server" ctx_id=3a986303-4a72-4158-8ffe-36799a683c1e
chirpstack-application-server_1 | time="2021-09-26T14:33:22Z" level=info msg="finished unary call with code OK" ctx_id=83452df4-0a42-469b-b19a-bc54ba66a25d grpc.code=OK grpc.method=HandleTxAck grpc.service=as.ApplicationServerService grpc.start_time="2021-09-26T14:33:22Z" grpc.time_ms=1.572 peer.address="172.19.0.8:59136" span.kind=server system=grpc
chirpstack-application-server_1 | time="2021-09-26T14:33:22Z" level=info msg="integration/mqtt: publishing event" ctx_id=83452df4-0a42-469b-b19a-bc54ba66a25d dev_eui=a81758fffe044a33 qos=0 retain=false topic=application/1/device/a81758fffe044a33/event/txack
chirpstack-application-server_1 | time="2021-09-26T14:33:22Z" level=info msg="integration/http: publishing event" ctx_id=83452df4-0a42-469b-b19a-bc54ba66a25d dev_eui=a81758fffe044a33 event_type=txack url="http://192.168.0.118:3100?event=txack"
chirpstack-application-server_1 | time="2021-09-26T14:33:22Z" level=info msg="integration/logger: logging event" ctx_id=83452df4-0a42-469b-b19a-bc54ba66a25d dev_eui=a81758fffe044a33 type=txack
chirpstack-network-server_1 | time="2021-09-26T14:33:42Z" level=info msg="gateway/mqtt: gateway stats packet received" gateway_id=24e124fffef11584 stats_id=0a293608-200e-49c9-b332-dcc736e3dadf
chirpstack-network-server_1 | time="2021-09-26T14:33:42Z" level=info msg="storage: gateway state updated" ctx_id=0a293608-200e-49c9-b332-dcc736e3dadf gateway_id=24e124fffef11584
chirpstack-application-server_1 | time="2021-09-26T14:33:42Z" level=info msg="gateway updated" ctx_id=1ca7c6cf-ff25-43ef-9147-351d4aaedc03 id=24e124fffef11584 name=ursalinkhome
chirpstack-network-server_1 | time="2021-09-26T14:33:42Z" level=info msg="finished client unary call" ctx_id=0a293608-200e-49c9-b332-dcc736e3dadf grpc.code=OK grpc.ctx_id=1ca7c6cf-ff25-43ef-9147-351d4aaedc03 grpc.duration=27.794642ms grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService span.kind=client system=grpc
chirpstack-application-server_1 | time="2021-09-26T14:33:42Z" level=info msg="metrics saved" aggregation="[MINUTE HOUR DAY MONTH]" ctx_id=1ca7c6cf-ff25-43ef-9147-351d4aaedc03 name="gw:24e124fffef11584"
chirpstack-application-server_1 | time="2021-09-26T14:33:42Z" level=info msg="finished unary call with code OK" ctx_id=1ca7c6cf-ff25-43ef-9147-351d4aaedc03 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time="2021-09-26T14:33:42Z" grpc.time_ms=27.421 peer.address="172.19.0.8:59136" span.kind=server system=grpc
chirpstack-application-server_1 | time="2021-09-26T14:33:55Z" level=error msg="integration/http: publish event error" ctx_id=83452df4-0a42-469b-b19a-bc54ba66a25d dev_eui=a81758fffe044a33 error="http request error: Post \"http://192.168.0.108:5100/api/decoder?event=txack\": dial tcp 192.168.0.108:5100: i/o timeout" event_type=txack url="http://192.168.0.108:5100/api/decoder?event=txack"
