I’m using simple way to create downlink message from Server to node. Node is working class A.
by UI use base64 some payload and some ports( not zero). Enqueue payload and after uplink can see downlink, but FPort each just 0 : “FPort:0”
My node received message, recognized it correctly - But no any my payload presented?.
I’ve used different payload (few symbols, many symbols) - but sent package each time the same long (differently encoded) and in node receiving fully correct. And resutls the same - Header, MIC all recognied – but no payload. Can somebody help me – I really stack…
I’ve used API for different way to enqueue downlink corresponding examples:
{“devEUI”: “2022000002000021”,
“confirmed”: false,
“data”: “d6VaiAD/mSE=”,
“fPort”: 4
It’s enqueued correctly but after uplink message corresponding downlink still using FPort:0 and not placed any payload.
ANd node receiving message, MIC and other part all
I really need HELP, Please, somebody can say where I should see – I’ve check configuration files and not anything…
Absolutely strange situation…
Any idea, PLEASE
Downlink with fPort: 0 and a frmPayload means that the NS is sending mac-commands to the device. There is nothing wrong with, as mac-commands get priority over application payloads. It means that your application-payload (downlink) stays in the queue until the next downlink (if there are no more mac-commands that the NS needs to send).
Dear Brocaar, thanks a lot for your answer, but my problem exactly about that - I have queue loaded with my message and I can see that this framenumber is updating for next each time after uplink and downlink, but neve that message passed out – and I don’t understand. FCnt continue increasing on that page… and never gone out…
Really it looks as each time for uplink Chirpstack organizing downlink with Fport:0 and message still in queue. Also if queue is empty - still continued to send those MAC commands in answer to each uplink. Where that answer programmed ? I’ve check all configurations and cannot find any about that.
No any. Still the same. Nobody answering. I stopped that test with Chirpstak I’ve tested this system fully correctly with Loriot server. There that downlink working normally. Just registered GW and client. I don’t know why Chirpstack downlink not working.
ChirpStack is trying to send mac-commands to your device, but it looks like these are not being acknowledged and thus ChirpStack keeps re-trying. Because of that other payloads stay in the queue.
