Downlink with codec over MQTT problem
I created chirpstack v4 demo docker. I applied devices templates and codec. I work example with ST Microelectronic board.
I try MQTT downlink msg on NodeRED, but It doesn’t work codec parser if I don’t fill data value.
For Example:
Not working this packet:
        "devEui": "<DEV_EUI>",
        "confirmed": true,
        "fPort": 2,
        "data": "...",
        "object": {
            "led":1
Working this:
        "confirmed": true,
        "fPort": 2,
        "data": Buffer.from(msg.payload.params.led ? "1":"0").toString("base64")
What do I wrong?
references:
Nobody have any ideas? :slight_smile:
Please note that you should only specify data or object, not both. data is used for the raw (binary) data. object will be used by the codec to encode to a raw (binary) payload.
If that doesn’t work, please check the logs. Both the server logs as under device events in the web-interface.
Hello @brocaar,
After deleting the data row in the load, it worked.
Ex:
“devEui”: “<DEV_EUI>”,
“confirmed”: true,
“fPort”: 2,
“object”: {
“led”:1
Thanks a lot.
