Dear all,
I am using US915 band which downlink class C uses channel 923.3 MHz, DR8. However, my ED (LoPy) only accept DR0 to DR7. Can we change DR for downlink class C at server side?
Thanks in advance.
Dear all,
Thanks in advance.
Please see:
--rx2-dr value rx2 data-rate (when set to -1, the default rx2 data-rate will be used) (default: -1) [$RX2_DR]
https://docs.loraserver.io/loraserver/install/config/
After changing that value, issue a new OTAA (as the RX2 is signaled to your device part of the OTAA).
For ABP devices, please update your device-profile: https://docs.loraserver.io/lora-app-server/use/device-profiles/.
I solved it. Thanks for your support.
how did you solve it?
Actually, I did not change DR. We should keep it in default. My problem came from end-device’s code. After fixing code, it worked well.
could you sahre your code?
I just use normal code from Pycom
https://docs.pycom.io/chapter/tutorials/lopy/lorawan-otaa.html
But you said that you fix the code, did you put the channels?
Thanks!
