DRAGINO GATEWAY JIT ERROR 2
Mon Sep 23 11:38:16 2024 daemon.info fwd[3183]: [INFO~][PKTS][server-DOWN] {“txpk”:{“imme”:false,“rfch”:0,“powe”:30,“ant”:0,“brd”:0,“tmst”:null,“tmms”:1411126729460,“freq”:866.55,“modu”:“LORA”,“datr”:“SF8BW125”,“codr”:“4/5”,“fdev”:null,“ncrc”:null,“ipol”:true,“prea”:null,“size”:15,“data”:“YOM/uQCABgABt2vB4Gus”}}
Mon Sep 23 11:38:16 2024 daemon.info fwd[3183]: [WARNING~][PKTS][server-DOWN] [WARNING~]Requested TX power is not supported (30dBm), actual power used: 27dBm
Mon Sep 23 11:38:16 2024 daemon.info fwd[3183]: lgw_time_on_air:1645: INFO: LoRa packet ToA: 78 ms
Mon Sep 23 11:38:16 2024 daemon.info fwd[3183]: [ERROR~][PKTS][server-DOWN] Packet REJECTED (jit error=2)
Mon Sep 23 11:38:16 2024 user.info chirpstack-mqtt-forwarder[540]: TX_ACK received, random_token: 18527, remote: 127.0.0.1:43326, error: TOO_EARLY
Mon Sep 23 11:38:16 2024 user.info chirpstack-mqtt-forwarder[540]: Sending ack event, downlink_id: 1084377183, topic:
What model of the Dragino gateway?
Do you set any custom configuration?
Do you use 4G for the gateway?
Dragino model : DL0S8N
custom configuration : no
Do you use 4G for the gateway: yes
Last time, I tried DLOS8N with 4G and ChirpStack 4 (<4.6).
Works ok for AS923.
I used UDP packet forwarder that time, btw.
According to the tx time, "tmms”:1411126729460, vs log UTC the packet is 15s early.
What does the log of an rx packet look like?
1411126729460 => 11:38:31
https://www.andrews.edu/~tzs/timeconv/timedisplay.php
I would recommend setting the rx1_delay config option to a higher value, e.g. rx1_delay=3. This gives you a bit more round-trip time (uplink - downlink). 1 sec (default) might be too short for cellular in some cases.
