Hi all,
I have tried porting the supplied decoder (intended for the things network) and using it in my device profile for the LGT-92 in chirpstack but I am having no success.
Decoder link from Dragino is here
https://www.dragino.com/downloads/index.php?dir=LGT_92/Decoder/
Does anyone have any experience with this end-node or have a decoder I could take a look at please?
I am planning on using it with thingsboard (integration in chirpstack). I have used other end-nodes with thingsboard so I am familiar with the config using the token, etc.
Any help would be greatly appreciated.
EDIT: When I attempt this, I only get 0’s for each of the variables in the decoder sent to thingsboard.
EDIT #2: Apparently decoder versions depend on firmware version. I will update firmware tomorrow and retest with matching decoder and post results.
Thank you,
Dan
The secret is in the name…
so use this:
function Decode(fPort, bytes){
var data = {
Latitude:
(bytes[0]<<24 | bytes[1]<<16 | bytes[2]<<8 | bytes[3]) / 1000000,
Longitude:
(bytes[4]<<24 | bytes[5]<<16 | bytes[6]<<8 | bytes[7]) / 1000000,
// Alarm status: boolean
ALARM_status: (bytes[8] & 0x40) > 0,
// Battery; 14 bits; unit: V
BatV: ((bytes[8] & 0x3f)<<8 | bytes[9]) / 1000,
// Motion detection mode; 2 bits
MD: {
"0": "Disable",
"1": "Move",
"2": "Collide",
"3": "Custom"
}[bytes[10]>>6],
// LED status for position, uplink and downlink; 1 bit
LON: (bytes[10] & 0x20) ? "ON" : "OFF",
// Firmware version; 5 bits
FW:150+(bytes[10] & 0x1f),
// Roll; signed 16 bits integer, MSB; unit:
// Sign-extend to 32 bits to support negative values: shift 16 bytes
// too far to the left, followed by sign-propagating right shift
Roll: (bytes[11]<<24>>16 | bytes[12]) / 100,
// Pitch: signed 16 bits integer, MSB, unit:
Pitch: (bytes[13]<<24>>16 | bytes[14]) / 100,
return data;
yep, worked that out today.
Consider this one solved. Thank you!
not sure if you have had a chance to have a play around with v4, but there is a function therein where you can import tons and tons of decoders… well worth the migration if you intend to start using loads of different devices…
Oh wow, thats excellent, I have deployed v4 yet, but I am definitely going to now. Thankyou for the heads up, greatly appreciated.
