Hi, I just deployed three LHT65 sensors in one of our customer premises. The gateway it’s a Kerlink iFemtoCell-evolution.
The sensors where fine until a couple minutes ago when one of them is throwing constantly this error every couple seconds:
We called the customer and told them to unplug and plug the gateway, just in case. This solved the issue for a bit a then the sensor went haywire a couple minutes later. The problem is that somehow this error broadcast message prevents my other sensors from reaching the LNS properly.
Does anybody know what’s causing this issue?
EDIT: After a couple of hours, the clogged device just made two normal uplinks, and then the other two device became clogged and started outputting the same error. Neither 3 of them are outputting correctly any data.
