Some of my network includes connections to helium which supplies a gateway b58 id, xxhash of the b58 as the gw eui and the gateway animal name. When we get an uplink from a helium device it looks like this below.
"deduplicationId": "80ba2279-96d2-43ef-b9de-394f2ad84b6e",
"time": "2023-09-06T21:30:02+00:00",
"deviceInfo": {
"devAddr": "78000024",
"adr": true,
"dr": 4,
"fCnt": 1011,
"fPort": 136,
"confirmed": false,
"data": "AAss6sQlDnUZ/wg=",
"object": {
"rxInfo": [
"gatewayId": "1037d81126469feb",
"uplinkId": 45747,
"rssi": -123,
"snr": -10,
"context": "BUzVUw==",
"metadata": {
"region_common_name": "AU915",
"gateway_id": "11s9eZL87C5b7g3eU12xaQn7kuc4SrczR2HP8m7uZUiQa2BUqn",
"gateway_name": "interesting-amethyst-mouse",
"region_config_id": "au915_1"
"crcStatus": "CRC_OK"
"gatewayId": "2864afc74baa57f1",
"uplinkId": 23247,
"rssi": -128,
"snr": -12.2,
"context": "T8P/rQ==",
"metadata": {
"gateway_id": "11kJam7LdWe43zeVm73ATLpSgdWL6ZQCqvXvYmUyt5UcZdWcxTV",
"gateway_name": "jovial-silver-hedgehog",
"txInfo": {
"frequency": 917000000,
"modulation": {
"lora": {
"bandwidth": 125000,
"spreadingFactor": 8,
"codeRate": "CR_4_5"
In the rxInfo - is it possible to set or manipulate the data given in the metadata field by helium or even add another field? I would like to add in the gateway lat and lon locations which i can lookup via helium cli or rpc directly or store them locally in a db as new ones are seen for quicker lookup perhaps.
Is this at all possible and if so how would I go about it? I was hoping it may be possible by using the gateway meta dynamic option in the chirpstack.toml but it may need to happen before this point.
