Hi there, I have a E890-915LG12 ebyte gateway,
I have connected to ttn test server but when I try to do same with chirpstack comunication is not possible, just appear Gateway never seen.
I am using chirpstack docker to run my server at local and I am trying to learn all this about IoT, so what other modification must I do on my server?
I really apreciate your help
datnus
2
It should be very straight forward.
Check the logs / status for chirpstack and chirpstack-gateway-bridge.
Likely database or MQTT issue.
If the gateway can send something to the chirpstack-gateway-bridge at port 1700/udp, then Chirpstack will see your gateway.
Where is located the logs file when set up with docker?
system
Closed
4
