Elsys Devices Downlink doesn't work
Hi everyone.
I have several types of Elsys devices that I want to change the device-config thought the Downlink , for example, the data transmission time can be increased from 10 minutes to 20 minutes.
I do this from this link Downlink generator – en (elsys.se)- SedndPer = 1200 , and I convert the Payload result to Based 64, and send it to the device as a Downlink on Chirpstack AS. But there is no change in the device configuration. Although it is confirmed.
Has anyone done this before?
Thank you
as this is quite an old topic but I currently stumbled across it:
If you would set the SendPer to 1200 then it would probably take a long time for the sensor to send information. As SendPeriod * Timebase = SendTime.
So setting the Timebase = SplPer would be probably the setting you have searched for.
Anyways. Some of the settings would need a reboot so you would need to add this information in the downlink. Examlpe:
fPort: 6
Downlink-HEX: 3E061400000258FE
More Info can be found here: App Note - Sensor Downlink Payload
