I want to enable the azure service bus integration into chirpstack-application-server.toml. Anyone has an example ?
How can i see if this integration is running ? It sow itself in the log ?
Thank you.
Thank you.
Please see Configuration - ChirpStack open-source LoRaWAN<sup>®</sup> Network Server for a full chirpstack-application-server.toml
confiuration example (including comments for each field that you need to configure).
Correct It is logged using info leve.
