Enabling All Channel for AS923_2
Hi, I am enabling the chirpstack network server using the docker.
I have also already made sure that all the channel is enabled in the gateway (I am using the Istation gateway with the MQTT forwarder).
However, I noticed that the gateway channel mask is only enabled on channels 0 and 1.
I noticed several topics on how to enable it, by enabling enabled_uplink_channels in the Loraserver part, however, I cannot find the Loraserver part in the docker GitHub that I’m using.
Anything you see referencing “Loraserver” is very old. Chirpstack used to be called Loraserver. If you are looking for the enabled_uplink_channels it is under chirpstack-docker → configuration → chirpstack → as923_2.toml (or whatever region you wish to use)
Although be sure you know what you are doing before you go changing enabled_uplink_channels.
As an example when I first started using Chirpstack my gateway bridge was forwarding the wrong MQTT topic prefix, this was causing some devices to stop working after the join-accept because Chirpstack was telling them to use the wrong channels. I blindly followed forum posts until I found one telling me to empty enabled_uplink_channels in my region configuration. This ‘fixed’ my issue, as now Chirpstack was telling devices to use ANY us915 channels instead of strictly the wrong channels, so every now and then my devices would send messages on the correct subband and while I thought I had solved my problem, it was actually causing major packet loss and other issues.
I’m not familiar with AS923 or channel masks so its possible your solution is completely valid, just do it with caution is all im saying.
@Liam_Philipp
I tried to include the enabled_uplink_channels with empty array, how ever the NS still not sending any channel mask other than 0 and 1.
When you use US915, do you this line “enabled_uplink_channels” in the us915.toml or do you add it on your own
I haven’t had to change my us915_x.toml files from the default. Here is my us915_0.toml:
# This file contains an example US915 example (channels 0-7 + 64).
[[regions]]
  # ID is an use-defined identifier for this region.
  id="us915_0"
  # Description is a short description for this region.
  description="US915 (channels 0-7 + 64)"
  # Common-name refers to the common-name of this region as defined by
  # the LoRa Alliance.
  common_name="US915"
  # Gateway configuration.
  [regions.gateway]
    # Force gateways as private.
    # If enabled, gateways can only be used by devices under the same tenant.
    force_gws_private=false
    [regions.gateway.backend]
      # The enabled backend type.
      enabled="mqtt"
      # MQTT configuration.
        # Topic prefix.
        # The topic prefix can be used to define the region of the gateway.
        # Note, there is no need to add a trailing '/' to the prefix. The trailing
        # '/' is automatically added to the prefix if it is configured.
        topic_prefix="us915_0"
        server="tcp://$MQTT_BROKER_HOST:1883"
        username=""
        password=""
        # Quality of service level
        # 0: at most once
        # 1: at least once
        # 2: exactly once
        qos=0
        # Clean session
        clean_session=false
        # Client ID
        # broker. A client id must be no longer than 23 characters. If left blank,
        # a random id will be generated by ChirpStack.
        client_id=""
        # Keep alive interval.
        # This defines the maximum time that that should pass without communication
        # between the client and server.
        keep_alive_interval="30s"
        ca_cert=""
        tls_cert=""
        # TLS key file (optional)
        tls_key=""
    # Gateway channel configuration.
    # Note: this configuration is only used in case the gateway is using the
    # ChirpStack Concentratord daemon. In any other case, this configuration
    # is ignored.
    [[regions.gateway.channels]]
      frequency=902300000
      bandwidth=125000
      modulation="LORA"
      spreading_factors=[7, 8, 9, 10]
      frequency=902500000
      bandwidth=125000
      modulation="LORA"
      frequency=902700000
      bandwidth=125000
      modulation="LORA"
      frequency=902900000
      bandwidth=125000
      modulation="LORA"
      frequency=903100000
      bandwidth=125000
      modulation="LORA"
      frequency=903300000
      bandwidth=125000
      modulation="LORA"
      frequency=903500000
      bandwidth=125000
      modulation="LORA"
      frequency=903700000
      bandwidth=125000
      modulation="LORA"
      frequency=903000000
      bandwidth=500000
      modulation="LORA"
      spreading_factors=[8]
  # Region specific network configuration.
  [regions.network]
    # surrounded gateways.
    installation_margin=10
    # RX window (Class-A).
    # Set this to:
    # 0: RX1 / RX2
    # 1: RX1 only
    # 2: RX2 only
    rx_window=0
    # RX1 delay (1 - 15 seconds).
    rx1_delay=1
    # RX1 data-rate offset
    rx1_dr_offset=0
    # RX2 data-rate
    rx2_dr=8
    # RX2 frequency (Hz)
    rx2_frequency=923300000
    rx2_prefer_on_rx1_dr_lt=0
    # Prefer RX2 on link budget.
    # Downlink TX Power (dBm)
    # be used.
    downlink_tx_power=-1
    # ADR is disabled.
    adr_disabled=false
    # Minimum data-rate.
    min_dr=0
    # Maximum data-rate.
    max_dr=3
    # Enabled uplink channels.
    # Use this when ony a sub-set of the by default enabled channels are being
    # used. For example when only using the first 8 channels of the US band.
    # Note: when left blank / empty array, all channels will be enabled.
    enabled_uplink_channels=[0,1,2,3,4,5,6,7]
    #enabled_uplink_channels=[]
    # Rejoin-request configuration (LoRaWAN 1.1)
    [regions.network.rejoin_request]
      # Request devices to periodically send rejoin-requests.
      enabled=false
      # The device must send a rejoin-request type 0 at least every 2^(max_count_n + 4)
      # uplink messages. Valid values are 0 to 15.
      max_count_n=0
      # The device must send a rejoin-request type 0 at least every 2^(max_time_n + 10)
      # seconds. Valid values are 0 to 15.
      # 0  = roughly 17 minutes
      # 15 = about 1 year
      max_time_n=0
    # Class-B configuration.
    [regions.network.class_b]
      # Ping-slot data-rate.
      ping_slot_dr=8
      # Ping-slot frequency (Hz)
      # set this to 0 to use the default frequency plan for the configured region
      ping_slot_frequency=0
As for AS923_x Region, the following is the default code
# This file contains an example AS923_2 configuration.
[[regions]]
  # ID is an user-defined identifier for this region.
  id="as923_2"
  description="AS923-2"
  common_name="AS923_2"
  [regions.gateway]
      enabled="mqtt"
        # Topic prefix.
        topic_prefix="as923_2"
        # Shared subscription name.
        # In case there are multiple ChirpStack instances sharing the same
        # subscription name, then the MQTT broker will deliver a gateway event
        # only to one subscriber. In case you have a production and
        # test-environment connected to the same MQTT broker, make sure that
        # each environment has its own subscription name, for example:
        # chirpstack_prod and chirpstack_tst.
        share_name="chirpstack"
        server="tcp://localhost:1883"
        username=""
        password=""
        # 0: at most once
        # 1: at least once
        # 2: exactly once
        qos=0
        # Clean session
        clean_session=false
        # Client ID
        client_id=""
        ca_cert=""
        tls_cert=""
        tls_key=""
    # is ignored.
      frequency=921400000
      bandwidth=125000
      modulation="LORA"
      spreading_factors=[7, 8, 9, 10, 11, 12]
      frequency=921600000
      bandwidth=125000
      modulation="LORA"
  [regions.network]
    # Set this to:
    # 0: RX1 / RX2
    # 1: RX1 only
    # 2: RX2 only
    rx_window=0
    rx1_delay=1
    rx1_dr_offset=0
    # RX2 data-rate
    rx2_dr=0
    rx2_frequency=921400000
    # Downlink TX Power (in dBm EIRP)
    # be used.
    # ADR is disabled.
    adr_disabled=false
    min_dr=0
    max_dr=5
      enabled=false
      max_count_n=0
      # 15 = about 1 year
      max_time_n=0
      ping_slot_dr=3
I made a little change where I add the rest of frequency of AS923_2 and the ‘enable_multiple_uplink’ so it looks like this
[[regions]]
  id="as923_2"
  [regions.gateway]
      enabled="mqtt"
        # Topic prefix.
        username=""
        password=""
        # 0: at most once
        # 1: at least once
        # 2: exactly once
        qos=0
        # Clean session
        clean_session=false
        # Client ID
        client_id=""
        ca_cert=""
        tls_cert=""
        tls_key=""
    # is ignored.
      frequency=921400000
      bandwidth=125000
      modulation="LORA"
      frequency=921600000
      bandwidth=125000
      modulation="LORA"
      frequency=921200000
      bandwidth=125000
      modulation="LORA"
      frequency=921800000
      bandwidth=125000
      modulation="LORA"
      frequency=922000000
      bandwidth=125000
      modulation="LORA"
      frequency=922200000
      bandwidth=125000
      modulation="LORA"
      frequency=922400000
      bandwidth=125000
      modulation="LORA"
      frequency=922200000
      bandwidth=250000
      modulation="LORA"
      spreading_factors=[7]
      frequency=922600000
      bandwidth=125000
      modulation="FSK"
      datarate=50000
  [regions.network]
    # Set this to:
    # 0: RX1 / RX2
    # 1: RX1 only
    # 2: RX2 only
    rx_window=0
    rx1_delay=1
    rx1_dr_offset=0
    # RX2 data-rate
    rx2_dr=0
    # be used.
    # ADR is disabled.
    adr_disabled=false
    min_dr=0
    max_dr=5
    # enabled_uplink_channels=[0 ,1, 2, 3, 4, 5, 6]
      enabled=false
      max_count_n=0
      # 15 = about 1 year
      max_time_n=0
      ping_slot_dr=3
If I change the ‘enabled_uplink_channels=[]’ to ‘enabled_uplink_channels=[0 ,1, 2, 3, 4, 5, 6,7]’ to this I got the following error
2024-03-18T02:43:31.544800Z  INFO chirpstack::cmd::root: Starting ChirpStack LoRaWAN Network Server version="4.6.0" docs="https://www.chirpstack.io/"
2024-03-18T02:43:31.544850Z  INFO chirpstack::storage: Setting up PostgreSQL connection pool
2024-03-18T02:43:31.600589Z  INFO chirpstack::storage: Applying schema migrations
2024-03-18T02:43:31.604288Z  INFO chirpstack::storage: Setting up Redis client
2024-03-18T02:43:31.643886Z  INFO chirpstack::region: Setting up regions
2024-03-18T02:43:31.644050Z  INFO setup{common_name=EU868 region_id=eu868}: chirpstack::region: Configuring region
2024-03-18T02:43:31.644243Z  INFO setup{common_name=AS923_3 region_id=as923_3}: chirpstack::region: Configuring region
2024-03-18T02:43:31.644406Z  INFO setup{common_name=US915 region_id=us915_1}: chirpstack::region: Configuring region
2024-03-18T02:43:31.644544Z  INFO setup{common_name=ISM2400 region_id=ism2400}: chirpstack::region: Configuring region
2024-03-18T02:43:31.644672Z  INFO setup{common_name=AS923_2 region_id=as923_2}: chirpstack::region: Configuring region
Error: Invalid channel
That is expected, because the AS923 region has two default channels, the rest must be manually added. This is different from the US915 region where all channels are pre-defined. Please refer to the Regional Parameters specs for more information.
I added additional channels in AS923.toml, but still only seeing the default 2 channels in Chirpstack /Network Server/Region/AS923 page. Please help
frequency=923200000
bandwidth=125000
modulation=“LORA”
  frequency=923400000
  bandwidth=125000
  modulation="LORA"
frequency=922200000
bandwidth=125000
modulation=“LORA”
frequency=922400000
bandwidth=125000
modulation=“LORA”
Maximum data-rate.
max_dr=5
enabled_uplink_channels=[]   <---- also added this enabled uplink channels command
Chirpstack Page
Uplink channels
  • 923200000 Hz
Min DR: 0, max DR: 5
  • 923400000 Hz
Please see the EU868 example:
