Enabling au_915 on the semtech SX1301 gateway
The gateway’s global.conf has the following parameters:
    "SX1301_conf": {
        "lorawan_public": true,
        "clksrc": 1, /* radio_1 provides clock to concentrator */
        "antenna_gain": 0, /* antenna gain, in dBi */
        "radio_0": {
            "enable": true,
            "type": "SX1257",
            "freq": 915600000,
	    "rssi_offset": -166.0,
            "tx_enable": true,
	        "tx_freq_min": 915000000,
            "tx_freq_max": 928000000
        "radio_1": {
            "enable": true,
            "type": "SX1257",
	        "freq": 916300000,
            "tx_enable": false
        "chan_multiSF_0": {
            /* Lora MAC channel, 125kHz, all SF, 916.8 MHz */
            "enable": true,
            "radio": 0,
            "if": -400000
        "chan_multiSF_1": {
            /* Lora MAC channel, 125kHz, all SF, 917.0 MHz */
            "enable": true,
            "radio": 0,
            "if": -200000
        "chan_multiSF_2": {
            /* Lora MAC channel, 125kHz, all SF, 917.2 MHz */
            "enable": true,
            "radio": 0,
            "if": 0
        "chan_multiSF_3": {
            /* Lora MAC channel, 125kHz, all SF, 917.4 MHz */
            "enable": true,
            "radio": 0,
            "if": 200000
        "chan_multiSF_4": {
            /* Lora MAC channel, 125kHz, all SF, 917.6 MHz */
            "enable": true,
            "radio": 1,
            "if": -300000
        "chan_multiSF_5": {
            /* Lora MAC channel, 125kHz, all SF, 917.8 MHz */
            "enable": true,
            "radio": 1,
            "if": -100000
        "chan_multiSF_6": {
            /* Lora MAC channel, 125kHz, all SF, 918.0 MHz */
            "enable": true,
            "radio": 1,
            "if": 100000
        "chan_multiSF_7": {
            /* Lora MAC channel, 125kHz, all SF, 918.2 MHz */
            "enable": true,
            "radio": 1,
            "if": 300000
        "chan_Lora_std": {
            /* Lora MAC channel, 500kHz, SF8, 917.5 MHz */
            "enable": true,
            "radio": 0,
            "if": 300000,
            "bandwidth": 500000,
            "spread_factor": 8
        "chan_FSK": {
            /* FSK 100kbps channel, 903.0 MHz */
            "enable": false,
            "radio": 0,
            "if": 300000,
            "bandwidth": 250000,
            "datarate": 100000
        "tx_lut_0": {
            /* TX gain table, index 0 */
            "pa_gain": 0,
            "mix_gain": 8,
            "rf_power": -6,
            "dig_gain": 0
        "tx_lut_1": {
            /* TX gain table, index 1 */
            "pa_gain": 0,
            "mix_gain": 10,
            "rf_power": -3,
            "dig_gain": 0
        "tx_lut_2": {
            /* TX gain table, index 2 */
            "pa_gain": 0,
            "mix_gain": 12,
            "rf_power": 0,
            "dig_gain": 0
        "tx_lut_3": {
            /* TX gain table, index 3 */
            "pa_gain": 1,
            "mix_gain": 8,
            "rf_power": 3,
            "dig_gain": 0
        "tx_lut_4": {
            /* TX gain table, index 4 */
            "pa_gain": 1,
            "mix_gain": 10,
            "rf_power": 6,
            "dig_gain": 0
        "tx_lut_5": {
            /* TX gain table, index 5 */
            "pa_gain": 1,
            "mix_gain": 12,
            "rf_power": 10,
            "dig_gain": 0
        "tx_lut_6": {
            /* TX gain table, index 6 */
            "pa_gain": 1,
            "mix_gain": 13,
            "rf_power": 11,
            "dig_gain": 0
        "tx_lut_7": {
            /* TX gain table, index 7 */
            "pa_gain": 2,
            "mix_gain": 9,
            "rf_power": 12,
            "dig_gain": 0
        "tx_lut_8": {
            /* TX gain table, index 8 */
            "pa_gain": 1,
            "mix_gain": 15,
            "rf_power": 13,
            "dig_gain": 0
        "tx_lut_9": {
            /* TX gain table, index 9 */
            "pa_gain": 2,
            "mix_gain": 10,
            "rf_power": 14,
            "dig_gain": 0
        "tx_lut_10": {
            /* TX gain table, index 10 */
            "pa_gain": 2,
            "mix_gain": 11,
            "rf_power": 16,
            "dig_gain": 0
        "tx_lut_11": {
            /* TX gain table, index 11 */
            "pa_gain": 3,
            "mix_gain": 9,
            "rf_power": 20,
            "dig_gain": 0
        "tx_lut_12": {
            /* TX gain table, index 12 */
            "pa_gain": 3,
            "mix_gain": 10,
            "rf_power": 23,
            "dig_gain": 0
        "tx_lut_13": {
            /* TX gain table, index 13 */
            "pa_gain": 3,
            "mix_gain": 11,
            "rf_power": 25,
            "dig_gain": 0
        "tx_lut_14": {
            /* TX gain table, index 14 */
            "pa_gain": 3,
            "mix_gain": 12,
            "rf_power": 26,
            "dig_gain": 0
        "tx_lut_15": {
            /* TX gain table, index 15 */
            "pa_gain": 3,
            "mix_gain": 14,
            "rf_power": 27,
            "dig_gain": 0
    "gateway_conf": {
	"gateway_ID": "AAAAAAAAAAAAAAAA",//  Gateway Radioenge
        /* change with default server address/ports, or overwrite in local_conf.json */
	"server_address": "router.us.thethings.network",
        "serv_port_up": 1700,
        "serv_port_down": 1700,
        /* adjust the following parameters for your network */
        "keepalive_interval": 10,
        "stat_interval": 30,
        "push_timeout_ms": 1000,
        /* forward only valid packets */
        "forward_crc_valid": true,
        "forward_crc_error": false,
        "forward_crc_disabled": false,
	/* GPS configuration */
        "gps_tty_path": "/dev/ttyAMA0",
        /* GPS reference coordinates */
        "ref_latitude": 0.0,
        "ref_longitude": 0.0,
        "ref_altitude": 0
Which file from the au_915 region is most suitable for use on my server, from au_915_0 to au_915_7?
