Hello friends,
I was trying to send some order to device, but I’ve got the error:
Code: DOWNLINK_PAYLOAD_SIZE
Level: ERROR
I read that the payload size is specified by the channel, but i don’t know why the maximum size is 11.
The Device profile is:
The region configuration is: `
[[regions]]
# Name is an user-defined identifier for this region.
name="us915_1"
# Common-name refers to the common-name of this region as defined by
# the LoRa Alliance.
common_name="US915"
# Gateway configuration.
[regions.gateway]
# Force gateways as private.
# If enabled, gateways can only be used by devices under the same tenant.
force_gws_private=false
[regions.gateway.backend]
# The enabled backend type.
enabled="mqtt"
# MQTT configuration.
# Event topic template.
event_topic="gateway/+/event/+"
# Command topic template.
command_topic="gateway/{{ gateway_id }}/command/{{ command }}"
server="tcp://mqtt-server:1883"
username=""
password=""
# Quality of service level
# 0: at most once
# 1: at least once
# 2: exactly once
qos=0
# Clean session
clean_session=true
# Client ID
client_id=""
# Region specific network configuration.
[regions.network]
# surrounded gateways.
installation_margin=10
# RX window (Class-A).
# Set this to:
# 0: RX1 / RX2
# 1: RX1 only
# 2: RX2 only
rx_window=0
# RX1 delay (1 - 15 seconds).
rx1_delay=10
# RX1 data-rate offset
rx1_dr_offset=0
# RX2 data-rate
rx2_dr=0
# RX2 frequency (Hz)
rx2_frequency=923300000
rx2_prefer_on_rx1_dr_lt=0
# Prefer RX2 on link budget.
# Downlink TX Power (dBm)
# be used.
downlink_tx_power=-1
# ADR is disabled.
adr_disabled=true
# Minimum data-rate.
min_dr=2
# Maximum data-rate.
max_dr=8
# Enabled uplink channels.
# Use this when ony a sub-set of the by default enabled channels are being
# used. For example when only using the first 8 channels of the US band.
# Note: when left blank / empty array, all channels will be enabled.
enabled_uplink_channels=[8, 9, 10, 11, 12, 13, 14, 15, 65]
# Class-B configuration.
[regions.network.class_b]
# Ping-slot data-rate.
ping_slot_dr=8
# Ping-slot frequency (Hz)
# set this to 0 to use the default frequency plan for the configured region
ping_slot_frequency=0`
Please someone could help us or if you need some extra info, let us know.
