Hi, Chirpstack ran stable, when suddenly the following error occurred immediately after midnight with the result that the gateway has no connection afterwards. After a server reboot everything runs fine again until midnight. I would be grateful for any ideas.
00:00:14 chirpstack-gateway-bridge[588]: time="2022-01-16T00:00:14" level=info msg="integration/mqtt: publishing event" event=stats qos=0 stats_id=xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx topic=gateway/xxxxxxxxxxxxxxxx/event/stats
00:00:15 chirpstack-gateway-bridge[588]: time="2022-01-16T00:00:15" level=error msg="[client] Connect comms goroutine - error triggered EOF" module=mqtt
00:00:15 chirpstack-gateway-bridge[588]: time="2022-01-16T00:00:15" level=error msg="mqtt: connection error" error=EOF
00:00:15 chirpstack-gateway-bridge[588]: time="2022-01-16T00:00:15" level=error msg="[client] Connecting to tcp://127.0.0.1:1883 CONNACK was not CONN_ACCEPTED, but rather Connection Refused: Not Authorised" module=mqtt
00:00:16 chirpstack-gateway-bridge[588]: time="2022-01-16T00:00:16" level=error msg="[client] Connecting to tcp://127.0.0.1:1883 CONNACK was not CONN_ACCEPTED, but rather Connection Refused: Not Authorised" module=mqtt
