Hello guys,
I used the NS with the initial configuration in EU868 and it worked perfectly.
Now, I have changed it to the AU915 configuration and I have run into the error below. I have already checked the entire configuration file.
Feb 28 13:54:27 jmrasp3bpi chirpstack-network-server[3223]: time=“2021-02-28T13:54:27-03:00” level=info msg=“gateway/mqtt: uplink frame received” gateway_id=a 840411ce008ffff uplink_id=16b97388-4139-43b1-9ce6-b84a945b0f0a
Feb 28 13:54:27 jmrasp3bpi chirpstack-network-server[3223]: time=“2021-02-28T13:54:27-03:00” level=info msg=“uplink: frame(s) collected” ctx_id=893629f8-9945- 4c84-af15-1107f535d514 mtype=UnconfirmedDataUp uplink_ids="[16b97388-4139-43b1-9ce6-b84a945b0f0a]"
Feb 28 13:54:27 jmrasp3bpi chirpstack-network-server[3223]: time=“2021-02-28T13:54:27-03:00” level=error msg=“uplink: processing uplink frame error” ctx_id=89 3629f8-9945-4c84-af15-1107f535d514 error=“get channel error: no channel found for frequency: -1, dr: 3”
Would anyone know how to indicate a way to correct this error?
Thank you in advance
Sincerely,
