I have installed Chirpstack-Gateway-Bridge and Chirpstack onto an RPi5. I started the gateway and it is running. I follow the instructions at
Getting Started Debian/Ubuntu
And when I check the systemctl status chirpstack I get:
According to documentation RPi is supported only for as gateway or full OS.
Ubuntu/Debian might not work.
https://www.chirpstack.io/docs/chirpstack-gateway-bridge/install/raspberry-pi.html
You need to install Chirpstack gateway os in full Raspberry Pi - ChirpStack open-source LoRaWAN® Network Server documentation for both to be supported. I don’t see v5 support just yet. Perhaps try and report back ![]()
Usually the best option is to start the service by hand to capture the full error to find out why it is failing to start.
