I’ve just tried installing chirpstack-application-server on a Ubuntu 18.04 machine, and I get the following error when I run chirpstack-application-server configfile
immediately after installing it.
FATA[0000] execute config template error: template: config:353:27: executing "config" at <.ApplicationServer.Integration.TLS>: can't evaluate field TLS in type struct { Marshaler string "mapstructure:\"marshaler\""; Backend string "mapstructure:\"backend\""; Enabled []string "mapstructure:\"enabled\""; AWSSNS config.IntegrationAWSSNSConfig "mapstructure:\"aws_sns\""; AzureServiceBus config.IntegrationAzureConfig "mapstructure:\"azure_service_bus\""; MQTT config.IntegrationMQTTConfig "mapstructure:\"mqtt\""; GCPPubSub config.IntegrationGCPConfig "mapstructure:\"gcp_pub_sub\""; Kafka config.IntegrationKafkaConfig "mapstructure:\"kafka\""; PostgreSQL config.IntegrationPostgreSQLConfig "mapstructure:\"postgresql\""; AMQP config.IntegrationAMQPConfig "mapstructure:\"amqp\"" }
I also had this happen to our existing installation which I was trying to upgrade to the latest version.
Thanks
James
