While monitoring log, I got the following error after starting Chirpstack Network Server:
root@testuser-Vostro-3902:~# chirpstack-network-server --log-level 4
INFO[0000] starting ChirpStack Network Server band=EU868 docs="https://www.chirpstack.io/" net_id=000000 version=3.11.0
INFO[0000] storage: setting up storage module
INFO[0000] storage: setting up Redis client
INFO[0000] storage: connecting to PostgreSQL
INFO[0000] storage: applying PostgreSQL data migrations
INFO[0000] storage: PostgreSQL data migrations applied count=0
INFO[0000] gateway/mqtt: connecting to mqtt broker server="tcp://localhost:1883"
INFO[0000] backend/gateway: connected to mqtt server
INFO[0000] gateway/mqtt: subscribing to gateway event topic qos=0 topic=gateway/+/event/+
INFO[0000] api: starting network-server api server bind="0.0.0.0:8000" ca-cert= tls-cert= tls-key=
FATA[0000] setup network-server api error: start api listener error: listen tcp 0.0.0.0:8000: bind: address already in use
I found some people are facing same kind of issue on the web, but nothing seems to work for me. So can anyone explain how to resolve this? Also Can I use another random port number to bind to, instead of 8000?
