Hello everyone:
I’m having problems trying to build Lora app server。After I run it
The general meaning of it is that the connection is not secure, the administrator did not configure the Web site.
6月 22 11:32:55 black-virtual-machine systemd[1]: Stopped LoRa App Server.
6月 22 11:32:55 black-virtual-machine systemd[1]: Started LoRa App Server.
6月 22 11:32:55 black-virtual-machine lora-app-server[3736]: time="2018-06-22T11:32:55+08:00" level=info msg="starting LoRa App Server" docs="https://www.loraserver.io/" version=1.0.1
6月 22 11:32:55 black-virtual-machine lora-app-server[3736]: time="2018-06-22T11:32:55+08:00" level=info msg="connecting to postgresql"
6月 22 11:32:55 black-virtual-machine lora-app-server[3736]: time="2018-06-22T11:32:55+08:00" level=info msg="setup redis connection pool"
6月 22 11:32:55 black-virtual-machine lora-app-server[3736]: time="2018-06-22T11:32:55+08:00" level=info msg="handler/mqtt: TLS config is empty"
6月 22 11:32:55 black-virtual-machine lora-app-server[3736]: time="2018-06-22T11:32:55+08:00" level=info msg="handler/mqtt: connecting to mqtt broker" server="tcp://localhost:1883"
6月 22 11:32:55 black-virtual-machine lora-app-server[3736]: time="2018-06-22T11:32:55+08:00" level=info msg="applying database migrations"
6月 22 11:32:55 black-virtual-machine lora-app-server[3736]: time="2018-06-22T11:32:55+08:00" level=info msg="handler/mqtt: connected to mqtt broker"
6月 22 11:32:55 black-virtual-machine lora-app-server[3736]: time="2018-06-22T11:32:55+08:00" level=info msg="handler/mqtt: subscribing to tx topic" qos=0 topic=application/+/device/+/tx
6月 22 11:32:55 black-virtual-machine lora-app-server[3736]: time="2018-06-22T11:32:55+08:00" level=info msg="migrations applied" count=0
6月 22 11:32:55 black-virtual-machine lora-app-server[3736]: time="2018-06-22T11:32:55+08:00" level=info msg="starting application-server api" bind="0.0.0.0:8001" ca-cert= tls-cert=/etc/lora-app-server/certs/http.pem tls-key=/etc/lora-app-server/certs/http-key.pem
6月 22 11:32:55 black-virtual-machine lora-app-server[3736]: time="2018-06-22T11:32:55+08:00" level=info msg="starting join-server api" bind="0.0.0.0:8003" ca_cert= tls_cert= tls_key=
6月 22 11:32:55 black-virtual-machine lora-app-server[3736]: time="2018-06-22T11:32:55+08:00" level=info msg="starting client api server" bind="0.0.0.0:8080" tls-cert=/etc/lora-app-server/certs/http.pem tls-key=/etc/lora-app-server/certs/http-key.pem
6月 22 11:32:55 black-virtual-machine lora-app-server[3736]: time="2018-06-22T11:32:55+08:00" level=info msg="registering rest api handler and documentation endpoint" path=/api
6月 22 11:33:50 black-virtual-machine lora-app-server[3736]: 2018/06/22 11:33:50 http2: server: error reading preface from client 127.0.0.1:41982: remote error: tls: unknown certificate authority
6月 22 11:33:50 black-virtual-machine lora-app-server[3736]: 2018/06/22 11:33:50 http2: server: error reading preface from client 127.0.0.1:41984: remote error: tls: unknown certificate authority
6月 22 11:33:51 black-virtual-machine lora-app-server[3736]: 2018/06/22 11:33:51 http2: server: error reading preface from client 127.0.0.1:41986: remote error: tls: unknown certificate authority
6月 22 11:46:21 black-virtual-machine lora-app-server[3736]: 2018/06/22 11:46:21 http2: server: error reading preface from client 127.0.0.1:41988: remote error: tls: unknown certificate authority
6月 22 11:46:21 black-virtual-machine lora-app-server[3736]: 2018/06/22 11:46:21 http2: server: error reading preface from client 127.0.0.1:41990: remote error: tls: unknown certificate authority
6月 22 11:46:21 black-virtual-machine lora-app-server[3736]: 2018/06/22 11:46:21 http2: server: error reading preface from client 127.0.0.1:41992: remote error: tls: unknown certificate authority
6月 22 11:46:57 black-virtual-machine lora-app-server[3736]: 2018/06/22 11:46:57 http2: server: error reading preface from client 127.0.0.1:41994: remote error: tls: unknown certificate authority
6月 22 11:46:57 black-virtual-machine lora-app-server[3736]: 2018/06/22 11:46:57 http2: server: error reading preface from client 127.0.0.1:41996: remote error: tls: unknown certificate authority
6月 22 11:46:57 black-virtual-machine lora-app-server[3736]: 2018/06/22 11:46:57 http2: server: error reading preface from client 127.0.0.1:41998: remote error: tls: unknown certificate authority
6月 22 11:47:21 black-virtual-machine lora-app-server[3736]: 2018/06/22 11:47:21 http2: server: error reading preface from client 127.0.0.1:42006: remote error: tls: unknown certificate authority
6月 22 11:47:21 black-virtual-machine lora-app-server[3736]: 2018/06/22 11:47:21 http2: server: error reading preface from client 127.0.0.1:42008: remote error: tls: unknown certificate authority
6月 22 11:47:21 black-virtual-machine lora-app-server[3736]: 2018/06/22 11:47:21 http2: server: error reading preface from client 127.0.0.1:42010: remote error: tls: unknown certificate authority
6月 22 12:56:50 black-virtual-machine lora-app-server[3736]: 2018/06/22 12:56:50 http2: server: error reading preface from client 127.0.0.1:42012: remote error: tls: unknown certificate authority
6月 22 12:56:50 black-virtual-machine lora-app-server[3736]: 2018/06/22 12:56:50 http2: server: error reading preface from client 127.0.0.1:42014: remote error: tls: unknown certificate authority
6月 22 12:57:30 black-virtual-machine lora-app-server[3736]: 2018/06/22 12:57:30 http2: server: error reading preface from client 127.0.0.1:42022: remote error: tls: unknown certificate authority
6月 22 12:57:30 black-virtual-machine lora-app-server[3736]: 2018/06/22 12:57:30 http2: server: error reading preface from client 127.0.0.1:42024: remote error: tls: unknown certificate authority
6月 22 12:57:30 black-virtual-machine lora-app-server[3736]: 2018/06/22 12:57:30 http2: server: error reading preface from client 127.0.0.1:42026: remote error: tls: unknown certificate authority
so ,I want to get some help. thanks!
