Error when trying to view OTAA keys for a device
In the UI, if I try to view the OTAA keys for a device, an error window pops up with:
“multi-dimensional arrays are not supported”
And I’m unable to view or modify the APPKEY.
I have several v4 instances running, and this is the only one with this behavoir.
Has anyone seen this before? Any ideas on what is going on?
Never seen this before, I’d be curious what happens if you try to pull the keys using gRPC API:
https://www.chirpstack.io/docs/chirpstack/api/api.html#api-GetDeviceKeysRequest
Might be able to fix it using updateDeviceKeys request:
https://www.chirpstack.io/docs/chirpstack/api/api.html#api-UpdateDeviceKeysRequest
Although chances are these just fail in error too.
Is it with every device or just one?
Failing with every device.
Both of these API calls fail.
Something wrong with your pSQL database then. Did you do Docker or ubuntu install?
It seems like something was corrupted in the device_keys table, but nothing obvious was wrong. Records could be queried directly from the DB and a full table dump did not reveal any obvious issues.
When an export of the DB to a new installation was performed, the problem persisted.
And update was made to v4.11 of Chirpstack and the problem has gone away.
I’m still unsure why this update fixed the problem - still looking into it.
