Hi Brocaar,
I’m updating lora-gateway-bridge,loraserver & lora-app-server to the latest one version 2. I’m using docker installation. After updating i cannot activate device again, if i switch to old version it activated without problem. The device is Class C with MAC version 1.0.2. Below are logs in activating process.
LoRa Server Logs
time=“2018-10-04T12:08:54Z” level=info msg=“packet(s) collected” dev_eui=110203040506070c gw_count=1 gw_ids=7276ff000b031b61 mtype=JoinRequest
** time=“2018-10-04T12:08:54Z” level=info msg=“device-queue flushed” dev_eui=110203040506070c**
** time=“2018-10-04T12:08:54Z” level=info msg=“device-session saved” dev_addr=02f79c6c dev_eui=110203040506070c**
** time=“2018-10-04T12:08:54Z” level=info msg=“device-activation created” dev_eui=110203040506070c id=32**
** time=“2018-10-04T12:08:54Z” level=info msg=“backend/gateway: publishing downlink frame” qos=0 topic=gateway/7276ff000b031b61/tx**
** time=“2018-10-04T12:09:00Z” level=info msg=“backend/gateway: uplink frame received”**
** time=“2018-10-04T12:09:00Z” level=warning msg=“creating insecure application-server client” server=“0.0.0.0:8001”**
** time=“2018-10-04T12:09:00Z” level=warning msg=“grpc: addrConn.createTransport failed to connect to {0.0.0.0:8001 0 }. Err :connection error: desc = “transport: Error while dialing dial tcp 0.0.0.0:8001: connect: connection refused”. Reconnecting…”**
** time=“2018-10-04T12:09:00Z” level=error msg=“processing uplink frame error” data_base64=QGyc9wKAAAB3IXht error=“get application-server client error: create application-server api client error: dial application-server api error: context deadline exceeded”**
** time=“2018-10-04T12:09:00Z” level=warning msg=“Failed to dial 0.0.0.0:8001: context canceled; please retry.”** -
LoRa App Server
time=“2018-10-04T12:08:54Z” level=info msg=“js: request received” message_type=JoinReq receiver_id=70b3d57ef00001af sender_id=010101 transaction_id=149818226
** time=“2018-10-04T12:08:54Z” level=info msg=“device-keys updated” dev_eui=110203040506070c**
** time=“2018-10-04T12:08:54Z” level=info msg=“js: sending response” message_type=JoinAns receiver_id=010101 result_code=Success sender_id=70b3d57ef00001af transaction_id=149818226**
Repeating the process but the result always same. Thanks
Regards
Jmuhbagir,
