I installed ChirpStack V4 on Raspberry Pi 5, I am getting this error:
debian@Chirpstack:~ $ systemctl status chirpstack-network-server
× chirpstack-network-server.service - ChirpStack Network Server
Loaded: loaded (/lib/systemd/system/chirpstack-network-server.service; enabled; preset: enabled)
Active: failed (Result: exit-code) since Mon 2024-11-04 21:57:58 MST; 3min 30s ago
Duration: 54ms
Docs: https://www.chirpstack.io/
Process: 998 ExecStart=/usr/bin/chirpstack-network-server (code=exited, status=1/FAILURE)
Main PID: 998 (code=exited, status=1/FAILURE)
CPU: 61ms
Nov 04 21:57:58 Chirpstack systemd[1]: chirpstack-network-server.service: Scheduled restart job, restart counter is at 5.
Nov 04 21:57:58 Chirpstack systemd[1]: Stopped chirpstack-network-server.service - ChirpStack Network Server.
Nov 04 21:57:58 Chirpstack systemd[1]: chirpstack-network-server.service: Start request repeated too quickly.
Nov 04 21:57:58 Chirpstack systemd[1]: chirpstack-network-server.service: Failed with result ‘exit-code’.
Nov 04 21:57:58 Chirpstack systemd[1]: Failed to start chirpstack-network-server.service - ChirpStack Network Server.
Any suggestions would be much appreciated!
datnus
November 6, 2024, 2:09pm
2
These commands are for ChirpStack v3.
Are you sure you installed ChirpStack v4?
In ChirpStack v4, it should be
sudo systemctl restart chirpstack.
brocaar
November 18, 2024, 12:48pm
3
If you installed ChirpStack v4, then there is no service named chirpstack-network-server
. It is named chirpstack
I appreciate your patience. I’ve been following the instructions on mobilefish.com for V3. Where can I locate the commands for V4?
Does all of this need to be installed by V4?
ChirpStack Gateway Bridge, ChirpStack Concentrator, and ChirpStack MQTT Forwarder
According to this link , I mounted “ChirpStack Gateway OS” on both the Raspberry 3 and Raspberry 4 Full images, but it doesn’t work; I keep getting errors when I try to mount the image files. Errors like “Something went wrong”, Raspberry Pi imager, says “The input file is not a valid disk image. The file size is 123572666 bytes is not a multiple of 512 bytes”
Is there a comprehensive installation guide for ChirpStack?
Please assist. I’ve never used ChirpStack before. Installing it on a Raspberry Pi 5 and then a server is my goal.
With kind regards,
Digisoles
system
Closed
February 19, 2025, 2:29am
5
