Hi brocaar, I am currently facing a server issue. I had added another organization in the web interface GUI , thereafter when we are passing the data to the newly created organization’s application node we are receiving data only once. There after the JSON_down stops in the log gateway. The logs of loraserver and lora-app-server are as follow,Please revert back asap
root@ubuntu-1gb-blr1-01:~# sudo journalctl -u loraserver -f -n 50
Journal file /run/log/journal/eef1323751bc4eb984f724371fde07bb/system.journal is truncated, ignoring file.
– Logs begin at Fri 2017-10-06 06:44:35 UTC. –
Oct 06 08:36:15 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:36:15Z” level=info msg=“backend/gateway: gateway stats packet received” mac=b827ebfffe9ccc85
Oct 06 08:36:15 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:36:15Z” level=info msg=“gateway updated” mac=b827ebfffe9ccc85
Oct 06 08:36:32 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:36:32Z” level=info msg=“backend/gateway: rx packet received”
Oct 06 08:36:32 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:36:32Z” level=error msg=“processing rx packet error: get node-session error: node-session does not exist or invalid fcnt or mic” data_base64=“gENlhwmAAAAC+MDT1QI=”
Oct 06 08:36:45 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:36:45Z” level=info msg=“backend/gateway: gateway stats packet received” mac=b827ebfffe9ccc85
Oct 06 08:36:45 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:36:45Z” level=info msg=“gateway updated” mac=b827ebfffe9ccc85
Oct 06 08:36:50 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:36:50Z” level=info msg=“backend/gateway: rx packet received”
Oct 06 08:36:50 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:36:50Z” level=error msg=“processing rx packet error: get node-session error: node-session does not exist or invalid fcnt or mic” data_base64=“gENlhwmAAAAC+MDT1QI=”
Oct 06 08:37:09 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:37:09Z” level=info msg=“backend/gateway: rx packet received”
Oct 06 08:37:09 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:37:09Z” level=error msg=“processing rx packet error: get node-session error: node-session does not exist or invalid fcnt or mic” data_base64=“gENlhwmAAAAC+MDT1QI=”
Oct 06 08:37:15 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:37:15Z” level=info msg=“backend/gateway: gateway stats packet received” mac=b827ebfffe9ccc85
Oct 06 08:37:15 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:37:15Z” level=info msg=“gateway updated” mac=b827ebfffe9ccc85
Oct 06 08:37:28 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:37:28Z” level=info msg=“backend/gateway: rx packet received”
Oct 06 08:37:28 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:37:28Z” level=error msg=“processing rx packet error: get node-session error: node-session does not exist or invalid fcnt or mic” data_base64=“gENlhwmAAAAC+MDT1QI=”
Oct 06 08:37:45 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:37:45Z” level=info msg=“backend/gateway: gateway stats packet received” mac=b827ebfffe9ccc85
Oct 06 08:37:45 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:37:45Z” level=info msg=“gateway updated” mac=b827ebfffe9ccc85
Oct 06 08:38:15 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:38:15Z” level=info msg=“backend/gateway: gateway stats packet received” mac=b827ebfffe9ccc85
Oct 06 08:38:15 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:38:15Z” level=info msg=“gateway updated” mac=b827ebfffe9ccc85
Oct 06 08:38:45 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:38:45Z” level=info msg=“backend/gateway: gateway stats packet received” mac=b827ebfffe9ccc85
Oct 06 08:38:45 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:38:45Z” level=info msg=“gateway updated” mac=b827ebfffe9ccc85
Oct 06 08:39:15 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:39:15Z” level=info msg=“backend/gateway: gateway stats packet received” mac=b827ebfffe9ccc85
Oct 06 08:39:15 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:39:15Z” level=info msg=“gateway updated” mac=b827ebfffe9ccc85
Oct 06 08:39:45 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:39:45Z” level=info msg=“backend/gateway: gateway stats packet received” mac=b827ebfffe9ccc85
Oct 06 08:39:45 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:39:45Z” level=info msg=“gateway updated” mac=b827ebfffe9ccc85
Oct 06 08:40:15 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:40:15Z” level=info msg=“backend/gateway: gateway stats packet received” mac=b827ebfffe9ccc85
Oct 06 08:40:15 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:40:15Z” level=info msg=“gateway updated” mac=b827ebfffe9ccc85
Oct 06 08:40:45 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:40:45Z” level=info msg=“backend/gateway: gateway stats packet received” mac=b827ebfffe9ccc85
Oct 06 08:40:45 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:40:45Z” level=info msg=“gateway updated” mac=b827ebfffe9ccc85
Oct 06 08:41:15 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:41:15Z” level=info msg=“backend/gateway: gateway stats packet received” mac=b827ebfffe9ccc85
Oct 06 08:41:15 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:41:15Z” level=info msg=“gateway updated” mac=b827ebfffe9ccc85
Oct 06 08:41:28 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:41:28Z” level=info msg=“node-session deleted” dev_eui=4786e6ed00490090
Oct 06 08:41:28 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:41:28Z” level=info msg=“node-session saved” dev_addr=013e6354 dev_eui=4786e6ed00490090
Oct 06 08:41:39 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:41:39Z” level=info msg=“node-session deleted” dev_eui=4786e6ed00490105
Oct 06 08:41:39 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:41:39Z” level=info msg=“node-session saved” dev_addr=09876543 dev_eui=4786e6ed00490105
Oct 06 08:41:45 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:41:45Z” level=info msg=“backend/gateway: gateway stats packet received” mac=b827ebfffe9ccc85
Oct 06 08:41:45 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:41:45Z” level=info msg=“gateway updated” mac=b827ebfffe9ccc85
Oct 06 08:42:15 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:42:15Z” level=info msg=“backend/gateway: gateway stats packet received” mac=b827ebfffe9ccc85
Oct 06 08:42:15 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:42:15Z” level=info msg=“gateway updated” mac=b827ebfffe9ccc85
Oct 06 08:42:45 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:42:45Z” level=info msg=“backend/gateway: gateway stats packet received” mac=b827ebfffe9ccc85
Oct 06 08:42:45 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:42:45Z” level=info msg=“gateway updated” mac=b827ebfffe9ccc85
Oct 06 08:43:15 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:43:15Z” level=info msg=“backend/gateway: gateway stats packet received” mac=b827ebfffe9ccc85
Oct 06 08:43:15 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:43:15Z” level=info msg=“gateway updated” mac=b827ebfffe9ccc85
Oct 06 08:43:45 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:43:45Z” level=info msg=“backend/gateway: gateway stats packet received” mac=b827ebfffe9ccc85
Oct 06 08:43:45 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:43:45Z” level=info msg=“gateway updated” mac=b827ebfffe9ccc85
Oct 06 08:44:15 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:44:15Z” level=error msg=“backend/gateway: acquire stats lock error: MISCONF Redis is configured to save RDB snapshots, but is currently not able to persist on disk. Commands that may modify the data set are disabled. Please check Redis logs for details about the error.”
Oct 06 08:44:21 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:44:21Z” level=info msg=“backend/gateway: rx packet received”
Oct 06 08:44:21 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:44:21Z” level=error msg=“backend/gateway: acquire uplink payload lock error: MISCONF Redis is configured to save RDB snapshots, but is currently not able to persist on disk. Commands that may modify the data set are disabled. Please check Redis logs for details about the error.”
Oct 06 08:44:39 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:44:39Z” level=info msg=“backend/gateway: rx packet received”
Oct 06 08:44:40 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:44:40Z” level=error msg=“backend/gateway: acquire uplink payload lock error: MISCONF Redis is configured to save RDB snapshots, but is currently not able to persist on disk. Commands that may modify the data set are disabled. Please check Redis logs for details about the error.”
Oct 06 08:44:45 ubuntu-1gb-blr1-01 loraserver[25931]: time=“2017-10-06T08:44:45Z” level=error msg=“backend/gateway: acquire stats lock error: MISCONF Redis is configured to save RDB snapshots, but is currently not able to persist on disk. Commands that may modify the data set are disabled. Please check Redis logs for details about the error.”
backend/gateway: acquire uplink payload lock error: MISCONF Redis is configured to save RDB snapshots, but is currently not able to persist on disk. Commands that may modify the data set are disabled. Please check Redis logs for details about the error.^C
^C
root@ubuntu-1gb-blr1-01:~# sudo journalctl -u lora-app-server -f -n 50
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: /home/travis/.gimme/versions/go1.9.linux.amd64/src/net/fd_unix.go:202 +0x52
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: net.(*conn).Read(0xc42000c1b0, 0xc42028f800, 0x800, 0x800, 0x0, 0x0, 0x0)
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: /home/travis/.gimme/versions/go1.9.linux.amd64/src/net/net.go:176 +0x6d
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: crypto/tls.(*block).readFromUntil(0xc4206c2f30, 0x7fe8a9b900f0, 0xc42000c1b0, 0x5, 0xc42000c1b0, 0x1)
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: /home/travis/.gimme/versions/go1.9.linux.amd64/src/crypto/tls/conn.go:488 +0x95
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: crypto/tls.(*Conn).readRecord(0xc4206f4a80, 0xb0e917, 0xc4206f4ba0, 0xc42042bc68)
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: /home/travis/.gimme/versions/go1.9.linux.amd64/src/crypto/tls/conn.go:590 +0xe0
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: crypto/tls.(*Conn).Read(0xc4206f4a80, 0xc4206aa000, 0x8000, 0x8000, 0x0, 0x0, 0x0)
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: /home/travis/.gimme/versions/go1.9.linux.amd64/src/crypto/tls/conn.go:1134 +0x110
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: bufio.(*Reader).Read(0xc4200dd260, 0xc4202f42d8, 0x9, 0x9, 0xc42042bd78, 0x4413f4, 0xc420ed3bf0)
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: /home/travis/.gimme/versions/go1.9.linux.amd64/src/bufio/bufio.go:213 +0x30b
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: io.ReadAtLeast(0xe9dd80, 0xc4200dd260, 0xc4202f42d8, 0x9, 0x9, 0x9, 0x7fdfbf, 0xc4208a2788, 0x0)
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: /home/travis/.gimme/versions/go1.9.linux.amd64/src/io/io.go:309 +0x86
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: io.ReadFull(0xe9dd80, 0xc4200dd260, 0xc4202f42d8, 0x9, 0x9, 0x410cd8, 0xc42042be28, 0x4295e6)
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: /home/travis/.gimme/versions/go1.9.linux.amd64/src/io/io.go:327 +0x58
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: github.com/brocaar/lora-app-server/vendor/golang.org/x/net/http2.readFrameHeader(0xc4202f42d8, 0x9, 0x9, 0xe9dd80, 0xc4200dd260, 0x0, 0xc400000000, 0xc42042be6d, 0xc4208a33e0)
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: /home/travis/gopath/src/github.com/brocaar/lora-app-server/vendor/golang.org/x/net/http2/frame.go:237 +0x7b
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: github.com/brocaar/lora-app-server/vendor/golang.org/x/net/http2.(*Framer).ReadFrame(0xc4202f42a0, 0xea3140, 0xc4208a33e0, 0x0, 0x0)
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: /home/travis/gopath/src/github.com/brocaar/lora-app-server/vendor/golang.org/x/net/http2/frame.go:492 +0xa4
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: github.com/brocaar/lora-app-server/vendor/google.golang.org/grpc/transport.(*framer).readFrame(0xc420183d70, 0xc4208a33e0, 0xc4208a33e0, 0x0, 0x0)
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: /home/travis/gopath/src/github.com/brocaar/lora-app-server/vendor/google.golang.org/grpc/transport/http_util.go:593 +0x2f
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: github.com/brocaar/lora-app-server/vendor/google.golang.org/grpc/transport.(*http2Client).reader(0xc4203c8f00)
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: /home/travis/gopath/src/github.com/brocaar/lora-app-server/vendor/google.golang.org/grpc/transport/http2_client.go:1104 +0xc0
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: created by github.com/brocaar/lora-app-server/vendor/google.golang.org/grpc/transport.newHTTP2Client
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: /home/travis/gopath/src/github.com/brocaar/lora-app-server/vendor/google.golang.org/grpc/transport/http2_client.go:252 +0xbd8
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: goroutine 122 [IO wait]:
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: internal/poll.runtime_pollWait(0x7fe8a9b8b730, 0x72, 0x0)
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: /home/travis/.gimme/versions/go1.9.linux.amd64/src/runtime/netpoll.go:173 +0x57
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: internal/poll.(*pollDesc).wait(0xc4200db518, 0x72, 0xffffffffffffff00, 0xea1ac0, 0xe9c400)
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: /home/travis/.gimme/versions/go1.9.linux.amd64/src/internal/poll/fd_poll_runtime.go:85 +0xae
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: internal/poll.(*pollDesc).waitRead(0xc4200db518, 0xc4206fe400, 0x400, 0x400)
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: /home/travis/.gimme/versions/go1.9.linux.amd64/src/internal/poll/fd_poll_runtime.go:90 +0x3d
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: internal/poll.(*FD).Read(0xc4200db500, 0xc4206fe400, 0x400, 0x400, 0x0, 0x0, 0x0)
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: /home/travis/.gimme/versions/go1.9.linux.amd64/src/internal/poll/fd_unix.go:125 +0x18a
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: net.(*netFD).Read(0xc4200db500, 0xc4206fe400, 0x400, 0x400, 0x54, 0x8, 0x0)
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: net.(*conn).Read(0xc42000c1a8, 0xc4206fe400, 0x400, 0x400, 0x0, 0x0, 0x0)
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: crypto/tls.(*block).readFromUntil(0xc420309aa0, 0x7fe8a9b900f0, 0xc42000c1a8, 0x5, 0xc42000c1a8, 0x0)
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: crypto/tls.(*Conn).readRecord(0xc4206f4700, 0xb0e917, 0xc4206f4820, 0x0)
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: crypto/tls.(*Conn).Read(0xc4206f4700, 0xc420138000, 0x8000, 0x8000, 0x0, 0x0, 0x0)
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: bufio.(*Reader).Read(0xc4200ddc80, 0xc4202f4658, 0x9, 0x9, 0x0, 0x10, 0xc42060ae80)
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: io.ReadAtLeast(0xe9dd80, 0xc4200ddc80, 0xc4202f4658, 0x9, 0x9, 0x9, 0xc420046a00, 0xc420426ea8, 0x8)
Oct 06 08:45:15 ubuntu-1gb-blr1-01 lora-app-server[8393]: io.ReadFull(0xe9dd80, 0xc4200ddc80, 0xc4202f4658, 0x9, 0x9, 0xc7076751634a201, 0x700000004, 0x0)
