Hi. I am using ST’s P-NUCLEO-LRWAN2 kit I connected it to The Things Network Europe server successfully. I want to connect my chirpstack server. I followed the steps of Connecting Gateway document from documentation. I will share my config but before I want to point out the connection. My gateway successfully connects here you can see it;
root@tunahan:~# tcpdump -AUq port 1700
tcpdump: verbose output suppressed, use -v[v]... for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), snapshot length 262144 bytes
12:27:32.068591 IP 78.186.43.200.static.ttnet.com.tr.50000 > nigering.com.1700: UDP, length 12
E..(......6.N.+..._..P.....J..........M.......
12:27:32.069484 IP nigering.com.1700 > 78.186.43.200.static.ttnet.com.tr.50000: UDP, length 4
E.. ..@.@....._.N.+....P........
12:27:37.140048 IP 78.186.43.200.static.ttnet.com.tr.50000 > nigering.com.1700: UDP, length 12
E..(......6.N.+..._..P....B..c/.......M.......
12:27:37.141668 IP nigering.com.1700 > 78.186.43.200.static.ttnet.com.tr.50000: UDP, length 4
E.. ..@.@..N.._.N.+....P.....c/.
And it get to the mqtt server here you can see it;
root@tunahan:~# mosquitto_sub -t "+/gateway/#" -v
eu868/gateway/{EUI64 comes here}/state/conn {EUI64 comes here}
And if I look into the chirpstack logs I can see this
Jul 18 12:06:32 {My ip address comes here} chirpstack[1004984]: 2024-07-18T12:06:32.062991Z INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_id="eu868" topic=eu868/gateway/{EUI64 comes here}/event/up qos=AtMostOnce json=false
Jul 18 12:17:16 {My ip address comes here} chirpstack[1004984]: 2024-07-18T12:17:16.044175Z INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_id="eu868" topic=eu868/gateway/{EUI64 comes here}/event/up qos=AtMostOnce json=false
But it is never seen on GUI I just don’t understand why. I tried everything in the forum.
here is my config files
chirpstack.toml
# Logging.
[logging]
# Log level.
level="info"
# PostgreSQL configuration.
[postgresql]
# PostgreSQL DSN.
# SSL mode options:
# * disable - no SSL
dsn="postgres://chirpstack:chirpstack@localhost/chirpstack?sslmode=disable"
# Max open connections.
# PostgreSQL connection pool.
max_open_connections=10
# Min idle connections.
min_idle_connections=0
# Redis configuration.
[redis]
servers=[
"redis://localhost/",
# Redis Cluster.
# instance.
cluster=false
[network]
net_id="000000"
# Enabled regions.
enabled_regions=[
# "as923",
# "as923_2",
# "as923_3",
# "as923_4",
# "au915_0",
# "cn470_10",
# "cn779",
# "eu433",
"eu868",
# "in865",
# "ism2400",
# "kr920",
# "ru864",
# "us915_0",
# "us915_1",
[api]
bind="0.0.0.0:8087"
# Secret.
# openssl rand -base64 32
secret="you-must-replace-this"
[integration]
enabled=["mqtt"]
[integration.mqtt]
server="tcp://localhost:1883/"
json=true
chirpstack-gateway-bridge.toml
# This configuration provides a Semtech UDP packet-forwarder backend and
# integrates with a MQTT broker. Many options and defaults have been omitted
# for simplicity.
# See https://www.chirpstack.io/gateway-bridge/install/config/ for a full
# configuration example and documentation.
[backend]
# Backend type.
type="semtech_udp"
# Semtech UDP packet-forwarder backend.
[backend.semtech_udp]
# ip:port to bind the UDP listener to
# Example: 0.0.0.0:1700 to listen on port 1700 for all network interfaces.
# This is the listener to which the packet-forwarder forwards its data
# so make sure the 'serv_port_up' and 'serv_port_down' from your
# packet-forwarder matches this port.
udp_bind = "[::]:1700"
# Integration configuration.
[integration]
# Payload marshaler.
# This defines how the MQTT payloads are encoded. Valid options are:
# * protobuf: Protobuf encoding
# * json: JSON encoding (easier for debugging, but less compact than 'protobuf')
marshaler="protobuf"
# MQTT integration configuration.
[integration.mqtt]
event_topic_template="eu868/gateway/{{ .GatewayID }}/event/{{ .EventType }}"
command_topic_template="eu868/gateway/{{ .GatewayID }}/command/#"
state_topic_template="eu868/gateway/{{ .GatewayID }}/state/{{ .StateType }}"
# MQTT authentication.
[integration.mqtt.auth]
# Type defines the MQTT authentication type to use.
# Set this to the name of one of the sections below.
type="generic"
# Generic MQTT authentication.
server="tcp://localhost:1883"
username=""
password=""
