why docker is required to build the binaries of chirpstack
lakshmana@lakshmana-Vostro-3400:~/projects/ao-inc/server_code/chirpstack$ cd chirpstack
lakshmana@lakshmana-Vostro-3400:~/projects/ao-inc/server_code/chirpstack/chirpstack$ make debug-amd64
cross build --target x86_64-unknown-linux-musl
info: downloading component ‘rust-std’ for ‘x86_64-unknown-linux-musl’
info: installing component ‘rust-std’ for ‘x86_64-unknown-linux-musl’
32.2 MiB / 32.2 MiB (100 %) 7.2 MiB/s in 4s ETA: 0s
ERROR: Cannot connect to the Docker daemon at unix:///home/lakshmana/.docker/desktop/docker.sock. Is the docker daemon running?
Error:
0: could not run container
1: when building custom image
2: when building dockerfile
3: docker build --label 'org.cross-rs.for-cross-target=x86_64-unknown-linux-musl' --label 'org.cross-rs.workspace_root=/home/lakshmana/projects/ao-inc/server_code/chirpstack' --tag cross-custom-chirpstack:x86_64-unknown-linux-musl-a81b8 --build-arg 'CROSS_DEB_ARCH=musl-linux-amd64' --build-arg 'CROSS_BASE_IMAGE=ghcr.io/cross-rs/x86_64-unknown-linux-musl:0.2.5' --file cross/Dockerfile.x86_64-unknown-linux-musl /home/lakshmana/projects/ao-inc/server_code/chirpstack
failed with exit status: 1
make: *** [Makefile:6: debug-amd64] Error 1
lakshmana@lakshmana-Vostro-3400:~/projects/ao-inc/server_code/chirpstack/chirpstack$ make dist
Keep these in this order, as aarch64 is based on Debian Buster (older),
the others on Bullseye. For some build scripts we want to build against
least recent LIBC.
cross build --target aarch64-unknown-linux-musl --release
info: downloading component ‘rust-std’ for ‘aarch64-unknown-linux-musl’
info: installing component ‘rust-std’ for ‘aarch64-unknown-linux-musl’
22.5 MiB / 22.5 MiB (100 %) 7.4 MiB/s in 3s ETA: 0s
Error:
3: docker build --label 'org.cross-rs.for-cross-target=aarch64-unknown-linux-musl' --label 'org.cross-rs.workspace_root=/home/lakshmana/projects/ao-inc/server_code/chirpstack' --tag cross-custom-chirpstack:aarch64-unknown-linux-musl-a81b8 --build-arg 'CROSS_DEB_ARCH=musl-linux-arm64' --build-arg 'CROSS_BASE_IMAGE=ghcr.io/cross-rs/aarch64-unknown-linux-musl:0.2.5' --file cross/Dockerfile.aarch64-unknown-linux-musl /home/lakshmana/projects/ao-inc/server_code/chirpstack
make: *** [Makefile:15: dist] Error 1
