I installed chripstack gateway bridge on raspberry pi and got the following error when I ran it.
raspberrypi chirpstack-gateway-bridge: level=fatal msg=“unmarshal config error” error=“3 error(s) decoding:\n\n* ‘integration.mqtt.auth.generic.ca_cert’ expected type ‘string’, got unconvertible type ‘[]interface {}’, value: ‘[/etc/chirpstack-gateway-bridge/ca.pem]’\n* ‘integration.mqtt.auth.generic.tls_cert’ expected type ‘string’, got unconvertible type ‘[]interface {}’, value: ‘[/etc/chirpstack-gateway-bridge/cert.pem]’\n* ‘integration.mqtt.auth.generic.tls_key’ expected type ‘string’, got unconvertible type ‘[]interface {}’, value: ‘[/etc/chirpstack-gateway-bridge/key.pem]’”
raspberrypi systemd[1]: chirpstack-gateway-bridge.service: Main process exited, code=exited, status=1/FAILURE
raspberrypi systemd[1]: chirpstack-gateway-bridge.service: Failed with result ‘exit-code’.
raspberrypi systemd[1]: chirpstack-gateway-bridge.service: Scheduled restart job, restart counter is at 5.
raspberrypi systemd[1]: Stopped ChirpStack Gateway Bridge.
raspberrypi systemd[1]: chirpstack-gateway-bridge.service: Start request repeated too quickly.
raspberrypi systemd[1]: Failed to start ChirpStack Gateway Bridge.
I doubly checked ca.pem/cert.pem/key.pem files and found no issues. They were copied and pasted from Semtech network server.
What is the issue?
Thanks,
