Apologies if this issue has been covered before. I’m having issue with pushing data payloads to the device queue.
I have several docker containers, two of which are …
- Chirpstack Application Server
- Home Assistant
Home assistant seems to cause a significant amount of i/o requests. This causes the Application server to ignore received MQTT messages, so there is no frmPayload attached to the downlink.
I can confirm that a MQTT message is being sent on the correct topic (application/*appID*/device/*eui*/tx
), as I will occasionally get successful payload queuing.
I can also confirm there is no significant delay on the MQTT topic publishing.
- Has anyone come across a problem like this before?
- Are there any settings I can modify to help mitigate this problem? I was considering raising the
get_downlink_data_delay
option inchirpstack-network-server.toml
but the higher that value gets the more the chance I miss the end node’s receive windows. - What kind of i/o are the Application and Network servers doing?
Thanks for your time.
